bitpod
#1 Posted : Thursday, April 6, 2017 4:49:08 PM(UTC)
bitpod
Is there anyway to fade out an audio input by using shortcuts?
Alex
#2 Posted : Thursday, April 6, 2017 5:51:34 PM(UTC)
Yep! SetVolume is the command to use. Scripting for creating the loop based on your will: logarithmic, straight, etc...
However normally a fade out has to be done in some "tempo", not always at the same speed. This is difficult to script!
bitpod on 4/7/2017(UTC)
bitpod
#3 Posted : Friday, April 7, 2017 11:59:48 AM(UTC)
bitpod
Hi DWAM,
Thanks for your reply. I don't suppose you could give me any pointers please as I have not done anything like this before. Happy to test a more basic fade as I think this will work.
Alex
xaver
#4 Posted : Friday, April 7, 2017 3:26:41 PM(UTC)
xaver
a realy fade would be great
At the moment, I do it with SetVolume, but I have to keep the original in a variable, to set the old Volume at Fade in
it would be much easier to have a fade out/in instead of manipulate the volume (adjusted by the sound people)
#5 Posted : Friday, April 7, 2017 3:43:12 PM(UTC)
Trying to do an audio fade in or out with a shortcut triggered by a keystroke doesn't make much sense in my opinion when it is so handy to do it with a fader which is made for that.
If you don't have a midi device (or a simple joystick), why don't you simply use vMix Audio Mixer?
bitpod
#6 Posted : Friday, April 7, 2017 3:51:17 PM(UTC)
bitpod
Agreed (for live production) but we are creating recordings and our setup is automated. Any help you can offer would be much appreciated :)
Alex
#7 Posted : Friday, April 7, 2017 4:02:09 PM(UTC)
If you still want to try, you can use SetVolume with a value like +=5 to increase volume by keypress or -=5 to decrease it. Several quick key presses in a row will create some sort of fade effect. That's the principle. I wouldn't do that!
A nicer effect can be achieved by creating a loop in a script that would use values like +=1 or -=1 for smoother fades. But still it would not fade according to a tempo speed. But I can't teach you how to script here. If you want to learn, there are hundreds of vb.net tutorials online.
xaver
#8 Posted : Friday, April 7, 2017 4:03:10 PM(UTC)
xaver
we have a nearly complete remote controler for vMix, except these shortcuts, which are missing
therefor the volountiers have to handle with vMix
it would be nice, the only have to deal with the remote control machine, so they can't change the config or something else, they are not "allowed"
ThomasK
#9 Posted : Saturday, June 8, 2019 11:33:58 PM(UTC)
ThomasK
Austria
Seems to be available now: SetVolumeFade
https://www.vmix.com/hel...utFunctionReference.html
trevsdad
#10 Posted : Monday, November 9, 2020 1:12:25 PM(UTC)
trevsdad
This function doesn't seem to work for the 'ever elusive vmix fade' as promised. I enter the value=1-100 Milliseconds i.e.(-=20) as indicated on the guide,
...annnnd nothing.
what am I doing wrong?
dmwkr
#11 Posted : Monday, November 9, 2020 4:07:31 PM(UTC)
dmwkr
Value = Volume,Milliseconds
So if you want to fade out in 2 seconds, the value would be:
0,2000
If you want to fade in to full volume in one second:
100,1000
