Inputs issue on AMD gpu [SOLVED]
Hi, I´m new using vmix. I represent a small Portuguese Church. We´ve been using wirecast for quite some time now, but it´s time to move to Vmix because it seems that our stream machine likes it much more and produces a smoother video. We are using a i5 2500k @ 4,5ghz, 8 Gb DDR3 1833mhz, Nvidia GTX 570, Blackmagic Intensity Pro capture card, Windows 10 Pro. On this rig everything seems to work very good, although it has not yet made any streaming. Because i´m new with this software, i´m trying to learn at home and because vmix folks kindly allow 2 licenses, i have also installed in my laptop. My laptop is composed by a i7 4720HQ, AMD Radeon R9 M265X, 8Gb DDR3. I´m having issues with the inputs sections, the bottom half screen sometimes start in blue background. When i use the mouse right click to minimize an input and maximize the screen doesn't refresh and it makes a mess, really hard to work with. I attached a image to show. Many thanks for this great software. Best regards from Portugal and God Bless you all!
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ MJV_Bat
Welcome to the forum! You say you are using a NVidia GTX 570 and it works fine, but your picture is from your laptop using the AMD Radeon R9 M200X (which is likely the issue). Can you clarify that the problem is on your laptop only?
He explained this already Gregory: he's got 2 PCs and does tests at home with an AMD based laptop. The nVidia PC is at church and has no issue.
His issue recalls me of another one, couldn't find it so far (not easy to look for a 3-letter keyword in the forum!). Also I'm wondering why Optimus is checked. Can't remember what Martin suggested as a possible solution.
But I'm pretty sure someone else posted a similar issue with AMD some weeks ago.
DWAM wrote:He explained this already Gregory: he's got 2 PCs and does tests at home with an AMD based laptop. The nVidia PC is at church and has no issue.
But I'm pretty sure someone else posted a similar issue with AMD some weeks ago. Yeap that´right on our Church rig the problem don´t exist (nVidia gpu). Since i want to learn at home because it´s more practical, this probleam arises only on my laptop with AMD gpu. Regarding Optimus being checked, i tried unchecked too. Made no effect. The only problem i was able to solve was regarding my lower thirds and changed output color format to UYVY and solved it. Now this input minimize/maximize issue is really annoying. Did google it a lot, with no productive results :( Thanks for your answers.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Try de-selecting low latency capture.
 1 user thanked Peter B for this useful post.
Peter B wrote:Try de-selecting low latency capture. No joy there. But i was able to solve it finally! Just disable Enable FlipEx on FullScreen and voilá!!! No more gargabe image! Thanks
