Daniel H
#1 Posted : Tuesday, April 4, 2017 1:35:22 PM(UTC)
Daniel H
I've seen similar requests previously but I'd like to stick a big hand up for some form of scheduler for video playlists, even in a basic form.
We'd ideally like to run a loop for most of the day but then at a certain time, kick start a prepared playlist for a few hours.
Even just a timer function whereby at a set time, a playlist is activate and put live.
Hopefully others would find this of use on their projects?
#2 Posted : Tuesday, April 4, 2017 1:49:36 PM(UTC)
Hi Daniel
you can set this up easy as pie with vMix UTC : https://forums.vmix.com/....aspx?g=posts&t=6468
You can also use Windows Task Scheduler to send API commands as explained in this post : https://forums.vmix.com/....aspx?g=posts&t=9554
Guillaume
#3 Posted : Tuesday, April 4, 2017 2:35:42 PM(UTC)
I quickly created a small tutorial for such scheduled tasks with vMix UTC.
Here it is:
https://forums.vmix.com/...ts&m=38181#post38181
Guillaume
