ASUS P8H77-V LGA1155 (iH77) SVGA (with DVI/HDMI/DP* if CPU with Grafic Core) Intel Core™ i7-3770 2xBlackmagic Design Intensity PRO (sources HDMI 1080i50) output only to Adobe FME (not fulscreen VGA) This configuration will be enough? (without a video card)
Without a video card? As i understand vMix, the GPU is the single most important part of the system, as this is where the imagestreams are being processed and mixed. I'd guess that even midlevel graphics cards are considerably more powerfull than intels integrated gpu cores, so this might be a severe bottleneck.
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Hi Alex,
The Intel HD 4000 which is built into the i7-3770 will be fine for mixing and streaming two HD sources. They are similar specs to one of the machines we have been testing with.
Martin vMix
