The output resolution can be the same as the resolution of the multi - screen graphics card? Is greater than 4096?
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi
vMix supports video resolutions up to 3840x2160 which is UHD.
As opposed to what its name underlies, vMix doesn't support 4K resolution. It conforms to broadcast/video standard resolutions which are SD (Pal and NTSC), HD (720p), FullHD (1080p), and UltraHD (2160p).
It is not usable for real 4K projects like DCI 4k with 4096x2160 resolution. It doesn't support 2K, DCI 2K or 4K Ultra Wide or 4K WHXGA. At the moment it doesn't support 8K either.
Guillaume
