drhurd
#1 Posted : Friday, March 17, 2017 11:18:27 PM(UTC)
drhurd
Has anybody else noticed that NDIs that were working yesterday are not working today?
renpro
#2 Posted : Wednesday, March 29, 2017 10:30:57 AM(UTC)
renpro
I too had the same problem with NDI this morning after installing vMix 19.0.0.37. We are a church and I run my scriptures and other graphics from a Lenovo laptop with Intel support. We were on Version 18.0.0.65 running NDI capture 18.x.x.x. I updated NDI on the Laptop but got errors on my vMix machine running v19. I could not even cancel capture error. I had to interrupt machine with Ctrl-Alt-Del and end vMix. I have reinstalled 18.0.0.65 on my streaming vMix desktop is capturing is working fine. I did not downgrade NDI on the Laptop so latest version 19.x.x.x works just fine there.
What could we be doing wrong on vMix 19.0.0.37? I am interested in vMix Call.
David in Kansas City
#3 Posted : Wednesday, March 29, 2017 11:01:32 AM(UTC)
Was thanked: 4670 time(s) in 1608 post(s)
Could you provide some more information on the error?
Thanks,
renpro
#4 Posted : Friday, March 31, 2017 11:43:24 AM(UTC)
renpro
Thanks,
Hello Martin. Fantastic Product in vMix. Below is my error file from vMix after installing 19.0.0.37 on my streaming desktop computer. I have loaded capture v19.0.0.3 on a laptop we use for feeding additional graphics. It is a Lenovo z560 Intel i3 Core CPU x64-based PC Windows/10 Intel HD Graphics version 8.15.10.2900. worked great with vMix 18.0.0.65
The following error is from my HP p6610f AMD Athlon(tm) II X4 635 Processor, 2900 Mhz, 4 Core(s), 4 Logical running Windows/10 Pro, 8GB RAM, geForce GTX 650 graphics card
19.0.0.37 - Unhandled - 3/30/2017 10:07:39 AM
vMix.NDI.NDIException: Could not initialize NDI Find
at vMix.NDI.NDIFind..ctor(Boolean showLocal)
at ok.n()
at ok.o(ListView a)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
19.0.0.37 - Unhandled - 3/30/2017 10:09:33 AM
at ok.n()
at ok.o(ListView a)
19.0.0.37 - Unhandled - 3/30/2017 10:09:35 AM
at ok.n()
at ok.o(ListView a)
19.0.0.37 - Unhandled - 3/30/2017 10:09:36 AM
at ok.n()
at ok.o(ListView a)
19.0.0.37 - Unhandled - 3/30/2017 10:09:37 AM
at ok.n()
at ok.o(ListView a)
19.0.0.37 - Unhandled - 3/30/2017 10:09:38 AM
at ok.n()
at ok.o(ListView a)
19.0.0.37 - Unhandled - 3/30/2017 10:09:39 AM
at ok.n()
at ok.o(ListView a)
19.0.0.37 - Unhandled - 3/30/2017 10:09:40 AM
at ok.n()
at ok.o(ListView a)
19.0.0.37 - Unhandled - 3/30/2017 10:25:42 AM
at ok.n()
at ok.o(ListView a)
I must use Ctrl-Alt-Del and task manager to get ahold of vMix.
#5 Posted : Friday, March 31, 2017 12:09:53 PM(UTC)
Hi
check this post concerning Athlon processors
https://forums.vmix.com/....aspx?g=posts&t=8461
Guillaume
agapesystem
#6 Posted : Friday, March 31, 2017 10:38:05 PM(UTC)
agapesystem
I have same problem after vMix updates to 19.0.0.37. Sometimes my vMix is crashed when NDI signal was received.
Windows Event Viewer says,
Faulting application name: VMIX64.EXE、Version: 19.0.0.37
Faulting application name: vMixNDIHelper.exe、Version: 2.0.0.5
Faulting module name: MSVCR120.dll、Version: 12.0.21005.1
My system are running like below,
VLC Media Player -> VLC plugin of NewTek NDI Tools Pack -> vMix
When before vMix updated, I had no issue above.
Thanks in advance.
#7 Posted : Tuesday, April 4, 2017 10:00:05 PM(UTC)
The NDI Find error means the CPU is not supported by NDI. This includes older AMD processors from about 2010 and lower.
agapesystem, please drop us an email with your registration key and go to Settings -> About to send a support report so we can investigate further, thanks.
renpro
#8 Posted : Thursday, April 6, 2017 12:29:46 PM(UTC)
renpro
DWAM wrote:
Hi
Guillaume
I went to the AMD Website and learned the following on 4/5/2017: AMD Athlon™ II Processors support: 3DNow!™ Technology, SSE, SSE2, SSE3, SSE4a
vMix 18.0.0.65 work just fine with the new NDI 18.0.0.3 It also works fine with 19.0.0.3. vMix 19.0.0.37 is a no show with NDI.
SportsNetUSA.net
#9 Posted : Thursday, April 6, 2017 12:53:23 PM(UTC)
SportsNetUSA.net
The AMD processor must support SSSE3, SSSE4. It's three (3) S's, not two (2).
See the post that DWAN provided.
If your desktop motherboard supports it, you could get an AMD FX series processor. The FX-83xx all support SSSE3 and they are inexpensive.
