bitpod
#1 Posted : Tuesday, March 28, 2017 5:47:34 PM(UTC)
bitpod
Hi vMixers,
I would love to know if it is possible to change (enable and disable) triggers with the scripting feature? I have an x-keys panel and was hoping to assign buttons to run code to achieve this.
I am no code guru (very limited experience of vba) so ideally need a library of examples available so I can then work it out from there. I can see much potential but am finding it tricky to get started.
I have looked at http://www.vmix.com/know...-using-scripting-and-api and http://www.vmix.com/help...ex.htm?WebScripting.html but that is only so much use to me without examples.
The other things I would like to do but don't know if possible are:
1. Load the last recorded file back in (on a key press) as an input to offer instant playback when required.
2. Make an x-keys key light up when pressed and then stay lit up until another of the defined set (e.g. a set of background colours for chromakey) is pressed. None of the actions listed in the dropdown is suitable from what I have tried.
3. Make a shortcut button have a different use on the second press? e.g press A once to start recording and then again to trigger a slide.
Sorry for all the questions - hopefully someone might be able to share some of their experiences.
Alex
