jpeg2RAW
#1 Posted : Monday, March 27, 2017 10:53:36 AM(UTC)
jpeg2RAW
Did the NDI minimum specs change at some point? One of my machines is running on a AMD 1090T (6 core cpu) which has SSE3 and SSE4a and it used to be able to use NDI. Just tried it again (it's been a few months or longer since I used NDI on this machine) and NDI crashes every time. Tried uninstalling it and it still crashes. So I looked up the minimum specs and it says SSSE3 are the minimum specs.
jpeg2RAW
#2 Posted : Monday, March 27, 2017 12:03:28 PM(UTC)
jpeg2RAW
Should have done a little more digging, found my answer here:
https://forums.vmix.com/....aspx?g=posts&t=8461
