is it possible to change the Stinger source with shortcuts?
for a show, we need three or four stinger transitions. If I could change them with a shortcut, this would be very helpfull
@ xaver
Sort of... The 'workaround' is to put your "Stinger clips" in a "List" and use the "List" as your source for your Stingers. Then you should be able to use "NextItem" and "PreviousItem" in "Shortcuts" to move up or down the list. The caveat is that the cut point needs to be the same for each clip or the Stinger needs to be adjusted for each respective clip (which might be a bit of a pain).
 2 users thanked IceStream for this useful post.
