GPBCTech
#1 Posted : Thursday, March 23, 2017 7:39:28 PM(UTC)
GPBCTech
Good Day All,
We have been doing Facebook Live for months now and for no reason now I get the following:
Streaming Status constantly disconnects and shows a status of closed but comes right back.
The stream button never changes colors and is always red.
I ping www.facebook.com and rarely ever lose a packet.
The encoding statistics show no drops on the input or output.
A clip from the log:
Wed Mar 22 2017 19:10:20 : Session Started
Wed Mar 22 2017 19:10:20 : Video Encoding Started
Wed Mar 22 2017 19:10:20 : Audio Encoding Started
Wed Mar 22 2017 19:10:51 : Primary - Network Status: NetConnection.Connect.Closed status
Wed Mar 22 2017 19:10:56 : Primary - Disconnected
Wed Mar 22 2017 19:10:59 : Primary - Re-establishing connection, attempt 1
Wed Mar 22 2017 19:11:00 : Primary - Reconnected to FMS/3,0,1,123
Wed Mar 22 2017 19:11:00 : Primary - Stream[10155478860180715] Status: Success
Wed Mar 22 2017 19:11:00 : Primary - Stream[10155478860180715] Status: NetStream.Publish.Start
Wed Mar 22 2017 19:11:32 : Primary - Network Status: NetConnection.Connect.Closed status
Wed Mar 22 2017 19:11:37 : Primary - Disconnected
Wed Mar 22 2017 19:11:38 : Primary - Re-establishing connection, attempt 1
Wed Mar 22 2017 19:11:39 : Primary - Reconnected to FMS/3,0,1,123
Wed Mar 22 2017 19:11:39 : Primary - Stream[10155478860180715] Status: Success
Wed Mar 22 2017 19:11:39 : Primary - Stream[10155478860180715] Status: NetStream.Publish.Start
Wed Mar 22 2017 19:12:09 : Primary - Network Status: NetConnection.Connect.Closed status
Wed Mar 22 2017 19:12:15 : Primary - Disconnected
Wed Mar 22 2017 19:12:17 : Primary - Re-establishing connection, attempt 1
Wed Mar 22 2017 19:12:18 : Primary - Reconnected to FMS/3,0,1,123
Wed Mar 22 2017 19:12:18 : Primary - Stream[10155478860180715] Status: Success
Wed Mar 22 2017 19:12:18 : Primary - Stream[10155478860180715] Status: NetStream.Publish.Start
Wed Mar 22 2017 19:12:49 : Primary - Network Status: NetConnection.Connect.Closed status
Wed Mar 22 2017 19:12:54 : Primary - Disconnected
Wed Mar 22 2017 19:12:56 : Primary - Re-establishing connection, attempt 1
Wed Mar 22 2017 19:12:58 : Primary - Reconnected to FMS/3,0,1,123
Wed Mar 22 2017 19:12:58 : Primary - Stream[10155478860180715] Status: Success
Wed Mar 22 2017 19:12:59 : Primary - Stream[10155478860180715] Status: NetStream.Publish.Start
Wed Mar 22 2017 19:13:30 : Primary - Network Status: NetConnection.Connect.Closed status
Wed Mar 22 2017 19:13:36 : Primary - Disconnected
Wed Mar 22 2017 19:13:37 : Primary - Re-establishing connection, attempt 1
Wed Mar 22 2017 19:13:37 : Primary - Reconnected to FMS/3,0,1,123
Wed Mar 22 2017 19:13:37 : Primary - Stream[10155478860180715] Status: Success
Wed Mar 22 2017 19:13:38 : Primary - Stream[10155478860180715] Status: NetStream.Publish.Start
Wed Mar 22 2017 19:14:09 : Primary - Network Status: NetConnection.Connect.Closed status
Wed Mar 22 2017 19:14:15 : Primary - Disconnected
Wed Mar 22 2017 19:14:16 : Primary - Re-establishing connection, attempt 1
Wed Mar 22 2017 19:14:16 : Primary - Reconnected to FMS/3,0,1,123
Wed Mar 22 2017 19:14:16 : Primary - Stream[10155478860180715] Status: Success
Wed Mar 22 2017 19:14:17 : Primary - Stream[10155478860180715] Status: NetStream.Publish.Start
Wed Mar 22 2017 19:14:47 : Primary - Network Status: NetConnection.Connect.Closed status
Wed Mar 22 2017 19:14:53 : Primary - Disconnected
Wed Mar 22 2017 19:14:55 : Primary - Re-establishing connection, attempt 1
Wed Mar 22 2017 19:14:55 : Primary - Reconnected to FMS/3,0,1,123
Wed Mar 22 2017 19:14:55 : Primary - Stream[10155478860180715] Status: Success
Wed Mar 22 2017 19:14:56 : Primary - Stream[10155478860180715] Status: NetStream.Publish.Start
Any help would be appreciated.
Thank You,
Grace Pointe Baptist Church Tech Team
#2 Posted : Thursday, March 23, 2017 7:57:05 PM(UTC)
Hi
it seems it is exactly the same issue than this:
https://forums.vmix.com/....aspx?g=posts&t=9742
Could you try another encoder, like FMLE or OBS, just to check if it's related to vMix or not?
fLipz
#3 Posted : Thursday, March 23, 2017 9:06:55 PM(UTC)
fLipz
DWAM wrote:
Hi
i too experienced the intermittent connection from Facebook Live since March 21 - March 23
i think the problem is from FB Server Side.
