Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
Has anyone tested NDI Cloud that could do a video showing how it works? I've tried and could get it to work.
Hi Alex
I got it working pretty easily. I saw your message on ndi.cloud forum. Still stuck?
What's your problem?
DWAM wrote:Hi Alex
What's your problem? YEAH Still stuck... Im can't get the Hamachi VPN to work. I think is the easiest way to get it to work, but all it does is to send me the full 100mb stream of the video and not the compressed one.
I don't use Hamachi. I think it's better not to use it unless you have to as stated in the documentation.
Are you sure you need it? Can't you simply setup the port forward to the NDI gateways hosts in your router ?
DWAM wrote:I don't use Hamachi. I think it's better not to use it unless you have to as stated in the documentation.
Are you sure you need it? Can't you simply setup the port forward to the NDI gateways hosts in your router ? Thats exactly what im not being able to do..
Quote:Thats exactly what im not being able to do.. What is the reason for this? Port Forwarding is very basic feature on almost all routers...
