Feature Requests
Frame/ms accuracy in Playlists
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Since it is already possible to manually edit the Start and Duration for playlist in the settings file (eg to "00:00:00.20"), I guess it is just a matter of allowing either frames or ms to be specified in the Playlist's setting. We need this for a live music video gig, where beat-synced switching between cameras would be cool. (madness started the request Playlist as input, and shorter durations, which I believe is a close - but much wider cigar).
Update, we ended up doing fast camera switches manually in our Live produced music video, but it would for sure had been nice being able to do those automatically ;)
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
At the moment, there are 2 solutions for ms accuracy in automated switching sequences
- vMix VB.net scripts (sleep command) - vMixUTC (timer command)
Both can be can triggered with a shorcut.
For this fb live video you did, you could have done it in few minutes with vMixUTC (and it's possible to use the KeyPress command to execute your vMix shortcuts)
Feature Requests
