NDI
Cannot see multiple NDI machines
Hi
is this Wifi AP on the same LAN network as your vMix host?
Do your wireless clients share the same IP range as your wired equipments?
Hi DWAM. Both running on the same net/wifi
Did you check your firewall settings?
Can you ping all hosts/devices?
Can you see your wireless sources with Newtek NDIMonitor for example ?
Hi
I have tried to disable all norton security - no effect I have not tried to ping I cannot se any wireless devices through NDImonitor
Make sure ping is ok. Not using Win10 firewall? Can you describe your IP network here? Ip range? Switch? Router? DHCP? etc...
Did you play with NDI Group Manager before? Is it installed ?
oh btw did you press the white round button in the app? It should turn red when NDI is on
Pimg is ok Windows firewall disabeled by Norton Zyxel router (fast) I have the NDI monitor and acces manager installed. I have not been playing with any of those.
My network is running fine both with LAN and wifi connections
Hi again
Yes, I have turned the red button on
Just to be able to understand where the problem is, could you try to get a NDI feed from a computer over wifi?
If it works, the problem is to be searched on the devices If it doesn't, the problem is certainly with the Wifi AP
NDI
