seb666
#1 Posted : Wednesday, March 22, 2017 8:03:41 AM(UTC)
seb666
I'm using a "MIDI Fighter 3D" as a MIDI Controller for vMix. I tried some Activator settings and could find some color changing with settings for different controllers. But I would really like to make full use of colors and blink effects of the controller. Is it possible to implement my own "MIDI Controller Map"?
Regards
Sebastian
curtismacd31
#2 Posted : Wednesday, March 22, 2017 10:52:25 AM(UTC)
curtismacd31
If you put it in the feature requests section Martin may add full support for that device.
thanks 1 user thanked curtismacd31 for this useful post.
seb666 on 3/22/2017(UTC)
stigaard
#3 Posted : Wednesday, March 22, 2017 2:49:44 PM(UTC)
stigaard
Denmark
Was thanked: 100 time(s) in 79 post(s)
For now, you can add the settings of your type of MIDI controller by adding a file in the folder C:\Program Files (x86)\vMix\activators.
An example is the a-generic.xml file, which is already in the folder, looking like this:
Code:
<?xml version="1.0" encoding="utf-8" ?>
<activators>
  <activatorType displayName="Off">
    <activatorValue displayName="Off" minimum="0" maximum="0" range="false" />
  </activatorType>
  <activatorType displayName="Button LED">
    <activatorValue displayName="Default" minimum="0" maximum="127" range="false" />
  </activatorType>
  <activatorType displayName="Fader">
    <activatorValue displayName="Volume" minimum="0" maximum="127" range="true" />
  </activatorType>
</activators>
Thereby your MIDI controller shows up in the activators windows when selecting which signals to map.
