Systems
New AMD Ryzen Computer Build with vMix
Joined: 4/4/2016(UTC) Posts: 236  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
Has anyone used AMD new Ryzen CPU and the RX480 with vMix? Here is a link to a great build by Max for use by 4K content creation. His conclusion was that this is the best bang for the buck right now. Seems like a great alternative build for the cost conscious. That is of course if it would work with vMix as well as Intel / nVidia does. Thanks everyone. Rich Shumaker
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
I think that Ryzen is useless for vmix it have one pciex16 or 2 x8. For postpo is a great option
 1 user thanked dark_ata for this useful post.
dark_ata wrote:I think that Ryzen is useless for vmix it have one pciex16 or 2 x8. For postpo is a great option That makes perfect sense. I wonder how far it could go then? Could you do a 4K production with it using NDI and a single capture card? Could it do a 4 camera HD production with a X8 Graphics card and a X8 Capture Card? I know that I read that nVidia and vMix are like Hot Knife and Butter so that was why I was asking, "Has anyone tried AMD? What happen?" Thanks dark_ata for your comment and I totally understand now the limitations. It is very similar to a laptop in regards to it's limitations. So maybe you slap a thunderbolt 3 card in the Ryzen MB second slot and call it a laptop alternative, heheh.
That's Perfect and thanks for the update. The more I think about the Ryzen the more I am treating it like a laptop. I don't think any motherboards have Thunderbolt 3 like laptops do. This months show had a great discussion on laptops and was super helpful. Thanks SportsNetUSA.net Rich Shumaker
There are some ASUS motherboards that have Thunderbolt with the ASUS ThunderboltEX3 card. https://www.asus.com/us/Motherbo...cessory/ThunderboltEX-3/ Z170-PREMIUM Z170-DELUXE Z170-PRO Z170-A Z170-AR SABERTOOTH Z170 MARK 1 SABERTOOTH Z170 S MAXIMUS VIII EXTREME MAXIMUS VIII HERO MAXIMUS VIII RANGER X99-DELUXE II X99-DELUXE X99-PRO/USB 3.1 X99-PRO X99-A/USB 3.1 X99-A X99-A II X99-E SABERTOOTH X99 RAMPAGE V EXTREME/U3.1 RAMPAGE V EXTREME There's the GIGABYTE Z170-UD5 TH motherboard. I would think other manufactures would be making them too.
Seems like the Thunderbolt card would work for any PCI slot so that is a great option to use on a MB with an open slot. I will research the MB you posted except I did not know if any of those were Ryzen MB's. Thanks again for your help SportsNetUSA.net Rich Shumaker
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ RichShumaker
AFAIK, it needs a PCIe x4 slot...
IceStream wrote:@ RichShumaker
Ice Thank you for the clarification as an X1 or X2 will not work and I had not considered that. I wonder if a X8 Graphics card will be good enough. I say that as the Ryzen spec from what was discussed only has 2 PCI slots max in a X8 X8 config and no X16 X4 config that I know of. Also this Ryzen cost benefit seems to be losing big time in regards to everything else. I guess I will need to wait and see if the Ryzen build by vMix really is worth while as it seems that the software needs to be well written and multithreaded to make true use of that CPU. Also from my own usage the GPU is much more necessary in my vMix system and the CPU is not as important, especially if the GPU enabled features are used. That darn bleeding edge sure does make you bloody. Rich Shumaker
If I am reading this MSI board correctly and I probably am not. https://www.msi.com/Moth...uctSpecification-sectionI could do PCI X8/X8 OR PCI X16. The Gen 2 X4 PCI is the part that I find interesting as I wonder if that could be used for capture. So 1 Graphics Card X16 and 1 Capture X4. Just guesses. Would love to drop a few bills and just try this stuff out. I know the Intel nVidia combo is solid as a rock so this Ryzen stuff is theory for me as I will stick to intel nVidia for my primary machine on the next build. Especially with all these issues that have come up. Rich Shumaker
Joined: 1/13/2010(UTC) Posts: 5,316  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
We've just completed preliminary testing of our Ryzen setup and the results aren't looking good at this stage.
For vMix workloads, the 1800X is currently ranking below the i7 6850k, with the i7 7700k speeding past both by a fair margin. NDI maxes out at about 14 inputs (1080p29.97) vs 17 on the 7700k
Most troubling are the very high render times under moderate load. These are significantly higher than even the X99 which wasn't that great to begin with.
We're using the GeForce 1070 in our tests, so some further driver updates may be needed to improve compatibility and results may be better when using Radeon GPUs.
Hope this helps.
Martin vMix
Thanks Martin that is horrible and awesome news. I think it will help keep many from going down that Ryzen rabbit hole which is very helpful in saving us time and money.
The thing I found interesting when reading and watching benchmarks is that the processor has a neural learning system for knowing what instructions are next. It would learn how to be better at the benchmarks and then get better on the 2nd 3rd and 4th times, it was weird and cool. I wonder if in time it will get better at vMix stuff the more it does it, I doubt it though. Also the Synergy with the RX480 is what would make this a more solid combo if it actually worked.
Time savings are worth their weight in gold and having a solid easy to build easy to use system is key. Thanks again for checking it out and saving us all the time.
Rich Shumaker
admin wrote:We've just completed preliminary testing of our Ryzen setup and the results aren't looking good at this stage.
Hope this helps.
Martin vMix Thanks Martin, I was just about to get a 1700/64GB/GTX1080 for second production machine (to work with my current I7 6900/64Gb/GTX1080). Do you think this poor performance situation with VMIX can change? Are there any adjustments or "fixes" that can be done on your side (on VMIX) to make Ryzen works better? Should we wait for new reports regarding AMD Ryzen CPUs and VMIX, from you? I believe many producers who have adopted VMIX (take me as example, I have 4 VMIX licenses) would love to have cheaper/better alternatives for 6/8 cores CPUs (also, looks like AMD will launch 12/16 Cores CPUs by the end of the year). Best regards. Joao Pott
 1 user thanked joaopott for this useful post.
Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
Any update on how the AMD processors are performing in vMix?
Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
lael wrote:Any update on how the AMD processors are performing in vMix? Still shitty, tried couple weeks ago. It was worse than 4th generation i7s in my benchmark (1700x)
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Is this a ThreadRipper, you have tried?
Steve
stevespaw wrote:Is this a ThreadRipper, you have tried?
Steve Also tried threadripper, I dont recall the specific performance metrics, but I ended up with X299 and i9 7900x, amaaaaazing performance :)
Thanks: 8 times Was thanked: 1 time(s) in 1 post(s)
Has anyone done any tests on Ryzen desktops with AMD GPUs?
@ Longur
Look at post # 11 again! Results have not been good...
Hope this helps.
Martin vMix Tests were done using a GeForce GPU and "results may be better when using Radeon GPUs." Was wondering if Radeon/AMD GPUs do indeed perform better with Ryzen CPUs on vMix.
Systems
