Hardware Compatibility
DeckLink Mini Recorder 4K latency?
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
Anybody use one of these yet? What kind of latency do you experience? Also I want to capture a odd 21:9 resolution with an additional card, will this card handle 2560x1080?
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi I do not own it but I used it once. Did not notice any particular latency. Here is the link for technical specs: https://www.blackmagicde...klink/techspecs/W-DLK-3321:9 format is not natively supported but you'll have enough pixels to capture it. However can't tell you if such a resolution will be accepted by the capture card as it does not conform to conventional video formats. Guillaume
Thanks for the info, my usage is for video game streaming so a few frames latency is ok, just didn't want to deal with a card that may have slow onboard encoding like the Elgato HD60 (non s) had. As far as the resolution I was going to get one for my 4k camera anyway so I will start with one, test it with the 21:9 resolution and if it works ill order a 2nd, if not Ill keep using the NDI method that I am using now.
I think NDI capture of your screen is a better option with more control over the source 21:9 resolution. With a capture card, if ever it works, you will need to add black borders or the image will be distorted.
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
I have two Mini Recorders Work just fine
Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
Siroki wrote:I have two Mini Recorders Work just fine @siroki - a little late, but are you using both in the same computer? any driver issues?
