4 Pages«<234
richardgatarski
#61 Posted : Friday, March 17, 2017 4:51:16 PM(UTC)
richardgatarski
Besides what I think about Microsoft's update police (no, spelled correctly).
For whatever it's worth, I have that patch installed and no problem om latest beta of v19.
Note, there was another patch today KB3150513 which I also have installed.
pm
#62 Posted : Saturday, March 18, 2017 10:54:56 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Patch KB3150513 was also installed by windows in the background some times later...
Found a forum entry, which describes that also some other "media software" have problems after installing a certain patch in combination with mpeg encoding/decoding.
https://answers.microsof...f-4fe3-8c52-c95b4f40d978
#63 Posted : Saturday, March 18, 2017 11:16:15 AM(UTC)
Was thanked: 4758 time(s) in 1633 post(s)
Just released the following temporary fix until Microsoft releases a formal update:
http://www.vmix.com/know...dows-10-update-kb4013429
#64 Posted : Saturday, March 18, 2017 11:22:29 AM(UTC)
Hi Martin
is this only for vMix 18 on Win10 Pro 64 bits?
Is it also required for vMix 19?
I do not seem to be having an issue. Is it only necessary when using inbuilt DVD/MPEG2 decoder ?
Guillaume
#65 Posted : Saturday, March 18, 2017 11:54:34 AM(UTC)
This fix should only be used if you see the problem when opening up recording settings, in both 18 and 19.
Everything else will work fine in vMix if you do not see this problem.
thanks 3 users thanked admin for this useful post.
DWAM on 3/18/2017(UTC), pm on 3/18/2017(UTC), IceStream on 3/19/2017(UTC)
Murchik
#66 Posted : Saturday, March 18, 2017 10:21:07 PM(UTC)
Murchik
Ukraine
Hello. Previously, I used version 17, this year I bought version 18 and ran into a problem ...... the first regulator (chroma key) did its work, and the second (key filter) its own - combining the tincture it turned out to achieve an excellent result. In version 18, the first regulator is not working at all (nothing changes anyway)! In this regard, it became harder to achieve a qualitative result! Very bad, very much!
What to do?
Murchik attached the following image(s):
#67 Posted : Saturday, March 18, 2017 10:27:25 PM(UTC)
Colour Key supports Green and Blue screens and is not changed from 17 to 18.
Click the eye dropper to select a green or blue portion of the background and then click one of the three [1],[2],[3] presets
to see which works more effectively, then you can fine tine the result.
RoboST
#68 Posted : Friday, March 24, 2017 2:10:12 PM(UTC)
RoboST
Installed Cumulative Update for Windows 10 Version 1607 for x64-based Systems (KB4015438) today, deleted the temp fix (DLL) from the vMix x64 folder, rebooted and not longer have that issue with the record config.
Can others check and update here?
4 Pages«<234
