8 Pages«<5678>
madness
#121 Posted : Tuesday, March 7, 2017 9:55:07 PM(UTC)
madness
Martin, As for my camera zoom issue, I tried duplicating on my laptop, and as you, I was not able to replicate, so I went back to version 18 on the problem system, and verified the problem did not occur. I then went back and re installed the latest beta, and was still unable to verify, so I'll chalk this up as a corrupt install. going from 32, to 33 didn't fix it, but going back to 18, and then forward to 19.0.0.33 did.
As for the luma key, I noticed one thing. The luma keys work correctly if the animated background was not active. As soon as I put the background into play/loop mode, it broke it.
hubert17
#122 Posted : Thursday, March 9, 2017 12:29:15 PM(UTC)
hubert17
sinc747 wrote:
delhen wrote:
please create a Vmixcall Application on google playstore
They have one. It's called the Chrome Browser. ;)
- Tom
And Firefox for Android, which can gives the option to choose the Front or Rear camera of your phone. :)
#123 Posted : Friday, March 10, 2017 6:50:14 AM(UTC)
For those that were seeing the dreaded firewall udp error in browsers when connecting to vMix Call, please try again
as a bug has just been fixed that impacted trial users in particular.
thanks 3 users thanked admin for this useful post.
sinc747 on 3/10/2017(UTC), ask on 3/10/2017(UTC), corporatejames on 3/14/2017(UTC)
madness
#124 Posted : Monday, March 13, 2017 10:12:04 PM(UTC)
madness
OnCompletion???
I can get OnCompletion to work on a video, but when that video is amultiview overlay to another input, it doesn't do anything. Is this by design? I would like to transition to a new input on the completion of the overlayed video, but can't get it to work.
corporatejames
#125 Posted : Tuesday, March 14, 2017 12:56:55 AM(UTC)
corporatejames
madness wrote:
OnCompletion???
Have you tried adding the oncompletion to actual video input? Thats how I normally do it. Or do use the video for other tasks?
#126 Posted : Tuesday, March 14, 2017 7:34:57 PM(UTC)
@ madness
AFAIK, yes, this is by design...
The workaround, is to build your "MultiView" on the actual video Input (much easier now with extra Overlays of vMix19) and a Virtual Copy of the original Input.
#127 Posted : Thursday, March 16, 2017 6:24:02 AM(UTC)
vMix 19 Preview Updated (19.0.0.35)
http://cdn.vmix.com/download/vmix19preview.exe
This is the second "Release Candidate" for vMix 19, with a number of bug fixes and updates including:
* Virtual Set zoom previews now update when layers are changed which is handy when using the Blank virtual set template
to build your own
* Added support for Sony PTZ 360 series
* Added resume support for MultiCorder, when a camera input is reset or changes video formats, MultiCorder will automatically restart the recording
* Further reduced latency in vMix Call
* Fixed some potential causes of bad a/v sync in the return video feed on some systems
* Fixed jerky video in vMix Call after long periods of time when using 1080 presets
* Fixed Caller name not showing up on Host during a vMix to vMix call
* Fixed Key/Fill not working independently on virtual inputs
* Fixed Chroma Key Anti Aliasing not working correctly when applied to some video formats
* Fixed low resolution NDI bug when using Chroma Key
* Fixed problem with vMix Desktop Capture not updating settings in some cases
thanks 7 users thanked admin for this useful post.
DWAM on 3/16/2017(UTC), xaver on 3/16/2017(UTC), pba on 3/16/2017(UTC), sinc747 on 3/17/2017(UTC), NeObr on 3/17/2017(UTC), hubert17 on 3/17/2017(UTC), stigaard on 3/24/2017(UTC)
xaver
#128 Posted : Thursday, March 16, 2017 6:28:43 AM(UTC)
xaver
is this also working for instant replay?
#129 Posted : Thursday, March 16, 2017 7:23:09 AM(UTC)
Resume support is already in Instant Replay since the latest 18 updates
hubert17
#130 Posted : Friday, March 17, 2017 1:26:20 PM(UTC)
hubert17
Hello Martin,
Is it still possible for you to add Activator support for Samson Graphite MD13 on your next release? Still hoping here... :)
xaver
#131 Posted : Friday, March 17, 2017 5:11:37 PM(UTC)
xaver
Thanks, that works
one little issue
if I have "KEY" and "FILL" on two different capture-inputs and reset the "KEY" Input, "FILL" forgets the "Key/Fill Input" in the Color Key Tab. If the Overlay is on at this moment, we get a black screen and our volunteers get in trouble
Is there a shortcut/API to set "Key/Fill"?
#132 Posted : Friday, March 17, 2017 10:18:58 PM(UTC)
hubert17 wrote:
Hello Martin,
We haven't found any documentation from them that says the lights on the controller can be controlled via MIDI.
Contact them for this info if you can and we would be happy to add it if it is actually possible.
#133 Posted : Saturday, March 18, 2017 8:19:28 AM(UTC)
vMix 19 Preview Updated (19.0.0.36)
* Added auto-detect for USB webcams that will default to MJPG as the video format for smoother video (instead of UYVY/YUY2)
* Fixed bugs with NDI preview generation
* It is now possible edit by dragging/zooming the preview when editing a Virtual Set Zoom preset
thanks 6 users thanked admin for this useful post.
DWAM on 3/18/2017(UTC), mjgraves on 3/18/2017(UTC), sinc747 on 3/19/2017(UTC), SHMD on 3/22/2017(UTC), NeObr on 3/22/2017(UTC), stigaard on 3/24/2017(UTC)
richardgatarski
#134 Posted : Saturday, March 18, 2017 2:08:37 PM(UTC)
richardgatarski
I noticed that the new option to specify Crop for Inputs by numbers, is not really "crop" but sort of "margin". I would prefer the specify crop. That is, for a 1280x720 production specify X1=200 and X2=200 (instead of as now 200,520).
EDIT: I turned this into the Feature request Specify crop settings by mumbers in different ways
JonnyNoblett
#135 Posted : Tuesday, March 21, 2017 5:34:38 AM(UTC)
JonnyNoblett
Is it possible to get a return feed of audio only to reduce the upload usage right down?
#136 Posted : Tuesday, March 21, 2017 5:43:39 AM(UTC)
No but you can reduce drastically required bandwidth by using EXTERNAL2 with a fixed color input
sunkast
#137 Posted : Tuesday, March 21, 2017 4:11:08 PM(UTC)
sunkast
I made a post a few days ago requesting this feature: https://forums.vmix.com/....aspx?g=posts&t=9714
hbb
#138 Posted : Wednesday, March 22, 2017 6:46:55 PM(UTC)
hbb
vmix social with version 19 bug?
anyone able to use it? vmix social is not running on same port as vmix web controller
#139 Posted : Wednesday, March 22, 2017 6:51:29 PM(UTC)
vMixSocial (8089) has never been on the same port as Web Controller (8088)
hbb
#140 Posted : Thursday, March 23, 2017 2:26:21 PM(UTC)
hbb
i meant the port vmix social was attempting to connect to web controller.
it never detected correct vmix web controller port.
but re-install fixed the issue
Guest (12)
8 Pages«<5678>
