VideolinkCanada
#1 Posted : Friday, March 17, 2017 3:09:10 PM(UTC)
VideolinkCanada
Does vMix take advantage of dual processor multithreading?
Has anyone tried this yet?
#2 Posted : Friday, March 17, 2017 3:34:20 PM(UTC)
Hi
I think it might potentially take advantage of 2 CPUs but basically vMix mainly uses GPU. I never could have 100% CPU load with an i7, so I'm not sure it's really interesting except if you want to run multiple external encoders/recorders on the same machine.
#3 Posted : Friday, March 17, 2017 3:53:45 PM(UTC)
@ VideolinkCanada
Simple answer: YES, it is being done
https://forums.vmix.com/....aspx?g=posts&t=8602
https://forums.vmix.com/....aspx?g=posts&t=8730
https://forums.vmix.com/....aspx?g=posts&t=6455
https://forums.vmix.com/....aspx?g=posts&t=5841
Just to mention a few threads from the past year or so that talk about it.
As DWAM suggests, much of vMix is GPU intensive, the biggest benefits would come in CPU intensive task like processing NDI signals and encoding for streaming and/or recording.
Mathijs
#4 Posted : Friday, March 17, 2017 8:21:35 PM(UTC)
Mathijs
That is because a i7 processor is at it's max above 50% and will start to drop frames around 60% because windows calculates percentage over the threads instead of the logical cores.
Hyperthreading can get around 10% extra margin, but I like to keep my system well under 50% cpu usage.
For lots of tasks, like the multicorder and recording in other formats than H.264 with hardware encoding, vMix is very depending on CPU and memory bandwidth.
I am quite happy with the Newtek codecs though, as they take much less cpu when multicording a lot of inputs.
