zenvideo
#1 Posted : Saturday, March 11, 2017 1:33:43 PM(UTC)
zenvideo
My latest "NDI doodle" is a 4-way colour-gradient pattern generator which transmits the image via NewTek's NDI.
It uses selectable colours for each of the four corners of the rectangle, although pairs can be set to the same value in order to achieve a simple 2-way gradient. The gradient image can either remain static or the colours can rotate in a clockwise (CW) or anticlockwise (CCW) direction. A slider control adjusts the period between colour changes (i.e. faster rotational speed as the slider moves to the right).
The gradient image can either fill the screen, be horizontally (H-Split) or vertically mirrored (V-Split) as two half-size rectangles, or be mirrored both horizontally and vertically (in Quad mode) using quarter-size rectangles. The Cloud overlay option adds a fixed fractal noise pattern, self-keyed over the background.
v1.0.0.2 is available to download from my zenvideo website (replaced by v1.0.0.3 on 14-Mar-2017)
zenvideo attached the following image(s):
thanks 6 users thanked zenvideo for this useful post.
sinc747 on 3/11/2017(UTC), vijay6672 on 3/11/2017(UTC), DWAM on 3/11/2017(UTC), Mathijs on 3/14/2017(UTC), mjgraves on 3/15/2017(UTC), Peter B on 12/25/2017(UTC)
kane
#2 Posted : Sunday, March 12, 2017 1:43:02 AM(UTC)
kane
Rank:: Advanced Member
Love it. Is this free? I notice there is there watermark at the bottom of the screen on the NDI output.
Kane Peterson
NewTek
zenvideo
#3 Posted : Sunday, March 12, 2017 5:15:57 AM(UTC)
zenvideo
Well, you don't have to pay me anything to download or use the current version, so in that sense it's free.
As for the watermark logo, for typical presenter-to-camera usage I'm guessing that it will get blocked out anyway, but I may well remove it at some point.
#4 Posted : Sunday, March 12, 2017 5:56:59 AM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Hi Martin,
Congrats, nice work!
I was more likely to use it for dynamic backgrounds for multiviews but this logo prevents from doing it. It's a pity!
Bien à toi,
Guillaume
Mathijs
#5 Posted : Tuesday, March 14, 2017 6:46:51 PM(UTC)
Mathijs
Was thanked: 81 time(s) in 72 post(s)
I also like it, very nice to get a live background very quickly. We are of course capable of zooming a bit on the input in vMix to get rid of the watermark, but I wonder why it is there anyways when there is no way to buy a license to get rid of it. So please remove it, or give us the option to pay you some money for the removal.
Also, resolutions above 1920x1080 do not work for me. Is this how it is at the moment or is there something wrong at my end?
zenvideo
#6 Posted : Wednesday, March 15, 2017 9:50:45 AM(UTC)
zenvideo
You may be pleased to hear that a new version (1.0.0.3) has been uploaded today, featuring a reduction in CPU usage at lower colour rotation speeds, plus removal of the "watermark" logo after several minutes usage.
See Note (5) in the Readme file.
DWAM on 3/15/2017(UTC)
#7 Posted : Wednesday, March 15, 2017 9:54:28 AM(UTC)
Great! Thanks Martin.
Why don't you make it a donationware software? Your tools are worth the money!
Guillaume
zenvideo
#8 Posted : Monday, December 25, 2017 2:37:52 PM(UTC)
zenvideo
There's a new version of the NDI Gradient Background generator now available, with the added feature of being able to load transparency masks, plus there's a (slightly rambling) video overview on YouTube showing how it can be used in vMix (like in the attached picture). Current version v1.01.5 available here.
Video Dave on 12/26/2017(UTC)
Peter B
#9 Posted : Monday, December 25, 2017 3:31:35 PM(UTC)
Peter B
Thanks for this, please make a donation possible.
It would be good to be able to use stills as well as colours.
zenvideo
#10 Posted : Tuesday, December 26, 2017 5:15:08 AM(UTC)
zenvideo
How would that work exactly, in the context of the current feature set?
Peter B
#11 Posted : Wednesday, December 27, 2017 12:09:24 PM(UTC)
Peter B
I thought adding texture frames and then animating them with rotation could make an interesting source.
A vMix snapshot could be one input of something that recently happened and then coloured / animated. An option to use the last snapshot could auto update this or the last four snapshots. Graphic frames designed for this could be another way to highlight elements.
On other mixers I used very soft edge slow rotating wipes as a way to animate graphics / live sources / border fills. A bit old hat but playing around can make some different effects.
vMix now has audio plugins, it now needs some video plugs.
thanks
zenvideo
#12 Posted : Wednesday, December 27, 2017 3:14:00 PM(UTC)
zenvideo
If I run through the current layer structure then perhaps you could indicate where your "user frames" would fit in?
Layer 1) 4-way RGB Colour gradient, in which the four corner colour sources can optionally be rotated (via progressive blending) in a clockwise/anti-clockwise direction. Note: I'm not actually rotating any images, nor have code to do so, I'm just "rotating" the sources for the 4-way gradient.
Layer 2) Optional RGBA image (currently the "cloud" images), keyed over Layer 1 using the alpha channel of the Layer 2 image. This layer can be animated by scrolling vertically up/down.
On the final NDI output, these combined images can have an alpha channel added by way of a user-supplied mask image.
