hellokitty
#1 Posted : Sunday, March 12, 2017 2:20:23 PM(UTC)
hellokitty
I have all my hdmi to sdi converters set to SDI A, I got a few months ago a Blackmagicdesign sdi to audio 4K. well after months of trouble shooting, i found out it wont work with SDI A, "Mini Converter SDI to Audio 4K includes everything you need to de-embed 4 channels of analog audio or 8 channels of AES/EBU digital audio from any SDI video connection. " Yeh right... what a nightmare it has been with there tech support. Anyways, Anybody have any thoughts on there experience with the Versions? I swear i switched all my micro converters to Level A for a reason, it was awhile ago. Thanks
#2 Posted : Monday, March 13, 2017 3:59:58 PM(UTC)
Hi
I just saw there is an update for some BMD converters models: version 7.0.7
https://www.blackmagicde...396448ccb09731cd4e553a54
They mention Level A support for some of them.
Not sure it will resolve your issue, but maybe you should drop an eye on this update.
Also make sure you use correct SDI cables for this.
Guillaume
hellokitty
#3 Posted : Monday, March 13, 2017 6:09:20 PM(UTC)
hellokitty
No update for my sdi to audio 4k. Support said they would see about it. There product page just lies and says "all sdi sources" Im using Blue Jeans Cables, very good company. They do custom work.
