Dear
I am new in vmix but after i test for 1 month , I think this is good
And I have one question I saw the audio select on below the camera scene when I switch between cam 1 and cam 2 it going to jump here and there can I set it not to jump from 1 to another
one more thing is it possible for the audio to fade in when selecting the channel of audio now is like cut in
PLease help
Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
If you click on the I of your camera input uncheck the box of automatically mix audio under the general tab. As long as that audio is on it will stay on while you click to the other camera. You will also need to do this with the other camera but turn its audio off if you only want audio from the one camera. If you want the other audio to come in but not be as loud then leave the automaticaly mix audio checked make sure the audio is on and adjust its volume in the mixer.
Greg
