Oren Fusion
#1 Posted : Friday, March 10, 2017 2:04:37 PM(UTC)
Oren Fusion
Hi there
How can I record the internal program via the multicorder? I can't inject it via the capture card....
Mathijs
#2 Posted : Friday, March 10, 2017 2:09:50 PM(UTC)
Mathijs
At settings go to External output / NDI
Enable NDI for Recording/external/output
Close settings and click add input.
Add NDI input, select vMix Output
Open multicorder settings, enable vMix output.
Of course, make sure you don't cut to the ndi input by mistake during the show, as that will loop your last frame with terrible audio.
