Audio issues when streaming
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
Hi all, I did a live stream on Sunday and had an audio problem....The video stream was good, but the audio was so low, that even at maximum volume, it was difficult to hear.....Audio from video clips on the PC played back ok, but the feed from the mixer, even though it was heard clearly, and showed high signal levels, did not give the same results in the stream... I am a bit puzzled, as I do not have any idea what could cause this. I was using FFmpeg.
What kind of sound card/device were you feeding the audio from your mixer into?
Rank: Guest
I think I may have found my error....I was using the wrong audio input to stream, instead of using vMix audio, I used the audio from the sound board feed....did a test, and found that the output audio should have selected vMix....
