kjones9999
#1 Posted : Sunday, February 26, 2017 12:07:38 PM(UTC)
kjones9999
This is an embarrassingly simple piece of software written with AHK that will countdown anytime up to an hour and automatically start recording (provided that recording has been setup) when the timer reaches zero. It will then start to count up. The window can be re positioned and ESC closes. It works off the web api, so it will open a window.
I am sure there is another/better way to do this...
I usually get everything ready prior to a show and have some time to do other tasks. I sometimes forget to press record when I get distracted.
I hope someone finds it useful. FYI. The software does prompt a smartscreen error in some versions of windows but I can assure you its safe.
If you would like to run the script in AHK, here it is:
File Attachment(s):
Vmix Countdown Recorder.zip (589kb) downloaded 88 time(s).
thanks 5 users thanked kjones9999 for this useful post.
vijay6672 on 2/26/2017(UTC), ask on 2/26/2017(UTC), corporatejames on 2/26/2017(UTC), stevespaw on 2/28/2017(UTC), avsoundguy on 3/20/2018(UTC)
ask
#2 Posted : Sunday, February 26, 2017 9:02:44 PM(UTC)
ask
Great little utility. ESC is the exit button. Are you open to feature requests?
kjones9999
#3 Posted : Sunday, February 26, 2017 9:52:10 PM(UTC)
kjones9999
Sure- anyway I can help.
theonlyboink
#4 Posted : Wednesday, March 15, 2017 9:18:03 AM(UTC)
theonlyboink
Could you alter the software so that it is
possible to input a higher value then the current maximum 99 minutes?
I would also like to see a different mode/feature:
"time of day & date"
The input a time of day and date that the recording will start.
I personally supervise a morning show radio-tv and it would
be great to have vMix start the recording at a given time.
Thous eliminating the possibility of forgetting it...
All the best
/Marcus
thanks 1 user thanked theonlyboink for this useful post.
stigaard on 3/15/2017(UTC)
#5 Posted : Wednesday, March 15, 2017 9:38:30 AM(UTC)
Why not simply use Windows Task Scheduler? It allows any type of command to be executed with very complete schedule options
Type Taskschd.msc in command prompt
The command to run is something like
cmd /c start http://vmix-ip:8088/api/?Function=StartRecording
PS : I personally use Cron for Windows as a Service for such applications. Same purpose: execute tasks on schedule. Here I would use wget or curl commands to vMix API.
DWAM attached the following image(s):
thanks 2 users thanked DWAM for this useful post.
theonlyboink on 3/17/2017(UTC), RichShumaker on 3/25/2018(UTC)
theonlyboink
#6 Posted : Friday, March 17, 2017 6:12:50 AM(UTC)
theonlyboink
@DWAM
Thanks,That worked.
Cheers!
/Marcus
Guest (5)
