JAIRODJ
#1 Posted : Saturday, February 25, 2017 11:00:41 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
When using excel in data source, it only allows to select the column and it is not possible to select the row.
Example: if you want to select for the same graph xaml:
HEADLINE1 = Column 2 - row1
HEADLINE2 = Column 2 - row2
HEADLINE3 = Column 2 - row3
etc.
This is not possible or I have not been able to do it.
Please add this option, it would allow to select independent data between rows and columns.
Thank you
