Joined: 5/3/2016(UTC) Posts: 28 Location: United Kingdom
Is there a way to run Version 19 without affecting my existing installation of Version 18. Can I just install to a different folder and select Trial?
David
Trying v19 will erase v18 but you can revert to v18 easily after. Simply reinstall...
Joined: 12/27/2012(UTC) Posts: 5,509  Location: Belgium Thanks: 316 times Was thanked: 1020 time(s) in 838 post(s)
install it in a different folder
DWAM wrote:Trying v19 will erase v18 but you can revert to v18 easily after. Simply reinstall... Don't have the time to do that, need to keep a working copy available. Last time we upgraded things went wrong and had to wait for help from here to sort it out. David
Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
Can you try it on another PC?
I always install in separate folder like vMix18; vMix19 ans switch between versions . license remains same
