Problem with firewire inputs
Hello, I'm trying to make an ultra portable system for direct streaming with one laptop and 2 cams JVC GY-750 via firewire. The result is that after adding them to vMix I have only 2 solid green screens and the wierd resolution 1440x1088 on the input info. Any ideas how can fix this? Screenshot
Joined: 2/6/2011(UTC) Posts: 79  Location: Belgium Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
No, but I've made a test with the editing program Edius and there were no problem with capturing via firewire. I guess the problem is with the decoding the signal in vMix, but I have no idea what to do...
Joined: 6/29/2011(UTC) Posts: 311   Location: Florida Thanks: 6 times Was thanked: 33 time(s) in 32 post(s)
What mode are the cameras in? Firewire only works for 1080i HDV Also try setting the cameras to 480i To see what happens.
The tests I've made was in 1080i . Tomorow I will try in SD, but i need them in HD format...
