Joined: 5/3/2016(UTC) Posts: 28 Location: United Kingdom
Trying to set up an output via External Out, using Intensity Pro card. Via HDMI to a monitor and it delayed/slow motion, moving a hand across camera you then see it in slow motion on the screen, it works fine on the output screen and on the Full screen output. Any ideas is a problem with Blackmagic card?
David
DWAM wrote:different framerate? Vmix output 25P External output 25P
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
What is the frame rate that the card is set for?
- Tom
sinc747 wrote:What is the frame rate that the card is set for?
- Tom Frame rate was 25P, have solved problem upgraded Blackmagic driver. Thanks Tom
