Unable to Assign multiple functions to a shortcut key
Joined: 5/3/2016(UTC) Posts: 28 Location: United Kingdom
To Assign multiple functions to a shortcut key does not work for some Functions because when you try and put them in the correct order they will not move up or down. My Shortcut list shown. I cannot move the last two items up or move items 7 & 8 down. If I press NumPad1 as it is, it performs item 7 but does not go onto item 9  David
Try setting up two very simple shortcuts that you can confirm work the way you expect them to, and then assign them to the same key.
Another way to check you current shortcuts is to edit the two shortcuts that are assigned to the same key, and assign them two different keys. Then you can verify that they function properly when you push the first and then the second shortcut.
Hope this is helpful.
- Tom
sinc747 wrote:Try setting up two very simple shortcuts that you can confirm work the way you expect them to, and then assign them to the same key.
- Tom Set the shortcuts up with different keys and worked ok and could move to where I wanted them, I then edited them to same key and it works OK. Do not know why they would not move before. When you select Fullscreen function option it comes up with another option of "Value" giving to the left Output, Preview, input, what is this option for does not appear to do anything? Under input selection there is no "Output" selection but "Active" which I assume is Output, Why does it not use "Output as it does with Other Functions? Why does it highlight some Shortcuts in RED in the list? Thanks Tom David David-NBC attached the following image(s):  shortcut4.png (45kb) downloaded 6 time(s). ShortCut3.png (33kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
Hi David Quote:When you select Fullscreen function option it comes up with another option of "Value" giving to the left Output, Preview, input, what is this option for does not appear to do anything? This command is useful to select which source for the FullScreen monitor See: http://www.vmix.com/help18/Display.htmlI guess you're not using the good command. Maybe you just want to select an input for PROGRAM? As the case may be, use CutDirect or ActiveInput commands here Check http://www.vmix.com/help...utFunctionReference.html for a complete list of commands and explanation for use. Guillaume
DWAM wrote:Hi David Quote:When you select Fullscreen function option it comes up with another option of "Value" giving to the left Output, Preview, input, what is this option for does not appear to do anything? This command is useful to select which source for the FullScreen monitor See: http://www.vmix.com/help18/Display.htmlI guess you're not using the good command. Maybe you just want to select an input for PROGRAM? As the case may be, use CutDirect or ActiveInput commands here Check http://www.vmix.com/help...utFunctionReference.html for a complete list of commands and explanation for use. Guillaume Above the "VALUE" setting is "INPUT" setting which does the same why do need both? David
@ David-NBC
The RED indicates "Cloned" keys (or duplicate functions on single key). As near as I can tell, the "Input" field of set-up screen has no real purpose for that "Function" (SetOutputFullscreen), the required field is the "Value" and your choices are Output (Program), Preview, MultiView (which has pre-selected options in Settings) or the actual Input (Input#) you want to send to the "FullScreen" feature. (I suspect that the reason the keys in your original post were not RED and wouldn't work is because they were not "Cloned" but I don't know for sure, maybe just an odd glitch)
Hope that helps.
