Opinion please regarding image sizes and type
what in your opinion is "the best" way to have your images to be useful to be loaded in titles As a practical example say country flags , depending on title they might be resized to often pretty small
do you prefer png or jpg (settings) do you have them on file per size needed or does one prefer to reduce the size on the fly Do you have them in different quality based on frame size to be used in other things to consider
Hi Doggy
for titles I create: - PNG over JPG - always at the good size - 300dpi (not sure it is "rationnal", I seem to see a difference)
If I need the same image at different sizes, I produce different versions and never resize.
If the image is not supposed to be moving, I always create a 1920x1080 file with alpha and my image well positionned in it, so that I'm sure it is always perfectly in place.
Bien à toi Guillaume
