Joined: 2/24/2014(UTC) Posts: 45   Location: Maine, USA Thanks: 26 times Was thanked: 15 time(s) in 12 post(s)
Hi Martin and team, Is there a possibility that a set of "SetTransition" shortcuts could be implemented for the four transitions? It could either be one shortcut where a transition number and value (transition name) are passed, or there could be four different inputs with just the value ("SetTransition1", "SetTransition2", etc). Transition1 is the most important because the T-Bar works with that transition, and I don't think there is currently a way to change the transition type from the API. I know the SetPictureTransition shortcut exists for Photo and PowerPoint inputs and it works great - this would be something similar, just for Transitions 1 through 4. Thank you for considering, and as always, great job with vMix!
 1 user thanked DYosua for this useful post.
Groups: Guests
Go to settings, Shortcuts, and set up what you want there.....
Bardos wrote: Go to settings, Shortcuts, and set up what you want there..... I don't think I can do what I'm looking for with the existing shortcuts. The current shortcuts allow you to call a transition directly, but none of them allow the user to assign a specific transition to the four default transitions. Being able to do this from outside vMix is most important for transition #1, since that is the one the T-Bar uses. So a third party T-Bar that uses the API can't change which transition it uses unless somebody changes the dropdown from within vMix. I'm hoping this shortcut could be added so third party applications can change transition 1 and then use the T-bar to activate that transition without needing to be right in front of vMix.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
+1 I posted the same request.
+1 This is what happens in Hardware professional switchers.
Joined: 4/14/2013(UTC) Views messages in topic : 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Rank:: Advanced Member
Joined: 10/25/2012(UTC) Posts: 182 Location: Barbados
+1 please, this is a great improvement.
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
DONE!!!!! in last version. It works perfect: Thank you, now, if this function is added to activators too, we can build very professional videoswitcher.
in my system it not works for stinger
what I'm doing wrong?
