Joined: 12/20/2016(UTC) Posts: 190   Location: Milano Was thanked: 21 time(s) in 13 post(s)
I'm making some test with activators. I connected Akai APC mini and if I select Akai APCmini in the type options, everything works. My problem is with "button led" (generic), if I select this option I have a strange behaviour and nothing works. I assume that in activators, Vmix sends just a midi note and if the external hardware receives that note it lights the led assigned to that note but with "button led" selected, Akai doesn't work. Same problem with Arduino. I loaded a code that works perfect when it receives midi notes by a daw but it doesn't work when it receives midi note by Vmix with "button led" selected. Any advice? Did someone experienced the same problem?
