Sending a signal to the custom RTSP server??
Joined: 7/31/2016(UTC) Posts: 69   Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Greeting. So I have a studio in which to record the show live. My question is how to send over Vmix stream in the RTSP protocol to open IP. Television, which will take over the signal requires it to be just the RTSP protocol, but I'm not sure how to send the signal. When I want to do stream there, I have some custom protocol RTSP, but I see there are only Custom RTMP protocol. Is there a way to send a signal to open the IP and that it is in the RTSP protocol? Please help me quickly because I have to give an answer as soon as possible
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 794 time(s) in 589 post(s)
Vmix only supports RTMP and WMV streaming
But you can output the signal using EXTERNAL (or use NDI) to feed an RTSP encoder.
Guillaume
PS : searching the forum prior to asking is a much better way to get quick answers...
tnx I realy need help for this quicky :(
Quote:you can output the signal using EXTERNAL (or use NDI) to feed an RTSP encoder.
You've got everything above
