Feature Requests
Some improvements in Virtual set
recently I tested virtual set and I miss several functions: 1) keyboard shortcuts to change the camera 2) audio follow video for the main image. I use virtual set dynamic transition to the PiP. If the picture of the PiP is on the whole screen, I would like to audio is only from this source. If I return to main screen, i would to switch to another audio source. When i have a shortcut for virtual set, this wasn't be a problem.
Joined: 3/7/2012(UTC) Posts: 2,686  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ bartek
1) + 1
2) Can you explain further, I think that what you suggest is already possible, if I understand you correctly.
Hi Quote:keyboard shortcuts to change the camera This can be done with multiview (instead of cam) in virtual set - make a multiview with a cam in overlay1, then use shortcut with SetMultiviewOverlay to switch cams For the audio, I don't really understand either...
@ DWAM
My understanding of request (1) is that it is referring to the "Camera View" of the Virtual Set and not one of the elements within the "MultiView" of said set. AFAIK, there are no "Shortcuts" for selecting any of the 4 configurable "Camera Views", (hence my +1), although there are "Shortcuts" to 'SetZoom', 'SetPanX' and 'SetPanY'... If, on the other hand, bartek is referring to changing an element within the Virtual Set, then I agree, it can be done with 'SetMultiViewOverlay'.
@Ice Stream
I understood he was referring to changing an element within the Virtual Set. But it is not clear I must admit...
Thanks: 9 times Was thanked: 3 time(s) in 3 post(s)
HI yes I'd love to be able to change whats on the screens in my virtual set with a short cut but cant find a way to do it.
- make a multiview with an input in overlay1, then use shortcut with SetMultiviewOverlay to switch inputs
When you can do this, then:
- load this multiview in your virtual set instead of loading your input.
When you use shorcut, your source will change in your virtual set.
Hi what would be the best solution would be that if you could select a video list as the input to the screens rather than an input itself. Otherwise what you are talking abut would result in the overlay moving out of place when you zoom into the virtual set I think? Is this possible?
@ Cormac
The "List" Input can be used as an Input in a "Virtual Set". In terms of the "the overlay moving out of place when you zoom" is more a factor of the design of the actual "Virtual Set" and how things are places in 3D space. A "Virtual Set" is essentially a MultiView Input.
Joined: 2/6/2015(UTC) Posts: 103  Thanks: 20 times Was thanked: 7 time(s) in 6 post(s)
Originally Posted by: bartek  2) audio follow video for the main image. I use virtual set dynamic transition to the PiP. If the picture of the PiP is on the whole screen, I would like to audio is only from this source. If I return to main screen, i would to switch to another audio source. When i have a shortcut for virtual set, this wasn't be a problem.
Bumping this 4 year old. I did a search and didn't see any follow ups or ways to get this to work, but maybe it just can't. And possibly shouldn't. What I believe was being asked, or at least what I would request is for A follow V as to what is displayed. In the attached picture. If 1 & 2 are side by side, play audio from both. When you transition to full screen either 1 or 2 the audio follows and mutes what is not full screen. It seems this might be best implemented with audio toggles on the Zoom screen allowing to choose what audio is on at that time? Might be a whack request that is functional in other ways, but just throwing the conversation out there. Thanks! -Jim  vMix64_2021-01-23_12-19-18.png (10kb) downloaded 0 time(s). vMix64_2021-01-23_12-23-04.png (19kb) downloaded 0 time(s).
Joined: 4/7/2021(UTC) Posts: 6  Location: Toronto Thanks: 2 times
Hey did you find a solution for this?
I'm running into the exact same issue and can't seem to figure it out. A simply A follows V is all I'm looking for :)
Originally Posted by: Jim_C  Originally Posted by: bartek  2) audio follow video for the main image. I use virtual set dynamic transition to the PiP. If the picture of the PiP is on the whole screen, I would like to audio is only from this source. If I return to main screen, i would to switch to another audio source. When i have a shortcut for virtual set, this wasn't be a problem.
Bumping this 4 year old. I did a search and didn't see any follow ups or ways to get this to work, but maybe it just can't. And possibly shouldn't. What I believe was being asked, or at least what I would request is for A follow V as to what is displayed. In the attached picture. If 1 & 2 are side by side, play audio from both. When you transition to full screen either 1 or 2 the audio follows and mutes what is not full screen. Hey hey did you find a solution for this? I'm running into the exact same issue and can't seem to figure it out. A simply A follows V is all I'm looking for :)
Feature Requests
