mark
#1 Posted : Thursday, February 9, 2017 10:09:39 PM(UTC)
mark
As the replay function already has 5 and 10 sec short cut button that you click with mouse.
It would be great to add this function to shortcut keys so it can be added to x-keys etc
Currently have to click in and out but the last 10 sec button is really great to capture some unexpected action that happens
all the time.
As far as I can see there is no way to add this to a short cut key.
ask
#2 Posted : Friday, February 10, 2017 2:14:05 AM(UTC)
ask
all the time.
Perhaps read the help? http://www.vmix.com/help...utFunctionReference.html
Look at the replay section.
If you are talking about the delay function, the time is set when you create the input.
http://www.vmix.com/help...ndex.htm?VideoDelay.html
stigaard
#3 Posted : Friday, February 10, 2017 3:03:39 AM(UTC)
stigaard
Denmark
As 'ask' references, the shortcut function that you are asking for does already exists.
The name of it is ReplayMarkInOutLive
(or ReplayMarkInOutRecorded if you want to use the current point on the timeline, but I dont think this is the case)
The function needs a value that is described as:
Number of previous seconds to use when creating a new event.
This means that you need to set the value to "5" if you want to create a five seconds replay clip.
thanks 1 user thanked stigaard for this useful post.
mark on 2/10/2017(UTC)
mark
#4 Posted : Friday, February 10, 2017 3:05:01 AM(UTC)
mark
Thankyou this was exactly the page I thought must exist I was trying to find
thankyou
