STADIORADIO
#1 Posted : Wednesday, February 8, 2017 3:32:17 PM(UTC)
STADIORADIO
Good evening everyone. I wanted to ask if there is a way to associate the effect "stinger" on replay with "Instant Replay" automatically
Cpilcher
#2 Posted : Wednesday, February 8, 2017 4:43:14 PM(UTC)
Cpilcher
Yes, You can set the Stinger as a transition for Instant Replay on the setup screen. When you set your cameras and audio sources in the Instant Replay settings screen you can set the Transition also. Choose your desired stinger and it will play automatically when you cut to replay.
Chuck
thanks 1 user thanked Cpilcher for this useful post.
STADIORADIO on 2/9/2017(UTC)
STADIORADIO
#3 Posted : Thursday, February 9, 2017 6:09:05 AM(UTC)
STADIORADIO
Grazie!!!
Thenaks!
Guest (5)
