Tip: Trouble Importing vMix Camera Into Zoom
Joined: 3/17/2013(UTC) Posts: 235  Location: Indiana Thanks: 95 times Was thanked: 30 time(s) in 28 post(s)
Ran into a bit of a snag when trying to import the camera from my vMix program into Zoom. What happened was I had many inputs in my preset and when I tried to import the vMix camera into Zoom it wouldn’t. When I reduced the number of inputs then the vMix camera would work (import) into Zoom. Whether or not this happens to you may depend on your computer build.
@George - What are the specs of your PC? Do you have a separate graphics card?
- Tom
sinc747 wrote:@George - What are the specs of your PC? Do you have a separate graphics card?
- Tom Tom, Intel i7 3.06 GHz 16 GB RAM NVIDIA GeForce GTX 750 Ti 2GB ~GeorgeR
You are talking about using the vMix External button to enable video through the "vMix Video" option in the Zoom camera setting, right?
That should work regardless of the number of inputs you are using. Something is off somewhere.
- Tom
sinc747 wrote:You are talking about using the vMix External button to enable video through the "vMix Video" option in the Zoom camera setting, right?
- Tom Tom, Durn, working now but it wouldn't work yesterday with my larger preset. Thanks, George
