madness
#1 Posted: : Tuesday, February 7, 2017 9:29:56 PM(UTC)
madness
Per my quest here...
https://forums.vmix.com/...p;m=34859&#post34859
I'm looking for a way to toggle the button LED, and then clear it using another command. I would use this for a scene sequence.
Button 1 for Scene 1
Button 2 for Scene 2
etc.
The way it sits now, I assign buttons to inputs, and several scenes would use the same inputs again, therefore lighting up all buttons that use that input. This adds confusion in the scene method, where I can simply hit the next unlit button to advance to the next scene.
Yes, I know I could use a playlist, and simply advance to the next playlist item, But I was liooking for something a little more visible to indicate show progress.
Thanks for your consideration.
