Systems
New Vmix Flightcase System
Joined: 7/1/2016(UTC) Posts: 48  Location: Italy Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
After a long period of planning and testing, I would like to present our new vMix system. A few basic facts: PC: - Mainboard: MSI Z97 Gaming 5 - Processor: intel i5 - RAM: 16 GB - HDD: 1x Samsung EVO 480 GB SSD: 1x WD 1TB HDD - Case: Techly I-CASE MP-P4HX-BLK Industrial Rack Case - Capture card: Decklink Duo 2 - Play Out card: Decklink Monitor mini Monitor: - Adam Hall 87413 19 "Sliding for LCD Monitor - Hanns-g 19 "monitor Router: - bintec RS123w Power supply: - Two-sided switchable rack connector strip with overvoltage protection Case: - Gator GR-10L Rack Case Control Unit: APC 40 MK II Mixer: - Behringer Xenyx UFX1204 connected via USB (To have each channel individually in Vmix as audio input) Approx. 3 packs of cable ties :-) Weight: 33 kg digitalalps attached the following image(s):  IMG_1367.JPG (717kb) downloaded 393 time(s). IMG_1370.JPG (799kb) downloaded 281 time(s). IMG_1371.JPG (809kb) downloaded 261 time(s). IMG_1373.JPG (849kb) downloaded 241 time(s). IMG_1376.JPG (877kb) downloaded 257 time(s).You cannot view/download attachments. Try to login or register.
 1 user thanked digitalalps for this useful post.
@ digitalalps
Congrats, nice job! Curious about the Behringer's ability for each channel individually in vMix, is there a procedure for that (I have never tried that with mine)
This modell has a 16 Channel usb audio interface so you can connect with one usb cable the device to your machine, in windows you see all the channels as single audio devices and can add the single devices as audio lnputs. Very usefull feature in multi language productions so can map the single channels to various audio channels in vmix (Master, A, B)
@ digitalalps
Perhaps it's the newer model, mine is an older Behringer Xenyx X1204 USB, and as I've said, I've never tried nor updated the drivers for individual channels through USB, so I was curious if it would work with mine and/or if there is a specific procedure to get there... I may have to investigate further, but somehow I suspect it's a feature of newer models.
The 1204 Usb has only 1 channel audio interface
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
Nice! I like it! I am thinking to make custom case for my setup. So I can like this in one case have PC, screen, keyboard, mouse...
Hope to get this soon
One question: Decklink Duo 2, how much inputs at same time can you get? This decklink playout BMD Mini Monitor for what do you use it?
Thx
This case is very useful. Remove the covers, plug in the power and go live.
Up to 4 SDI cameras can be connected to the Decklink duo 2.
The Decklink Monitor I use for different tasks:
- Connecting an external monitor for the speakers (Vmix External) - At a stream on Livestream.com depends on the decklink monitor a Vidiuu which streams to Livestream.com. -If events occur, in which we need a video wall, I connect these to the Decklink monitor.
digitalalps wrote:This case is very useful. Remove the covers, plug in the power and go live.
- Connecting an external monitor for the speakers (Vmix External) - At a stream on Livestream.com depends on the decklink monitor a Vidiuu which streams to Livestream.com. -If events occur, in which we need a video wall, I connect these to the Decklink monitor. Yes I was thinking that you use it for this stuff. Cool. I also have vidiU, but also on one TV station for sending signal they have LiveU so this monitor is very useful. LiveU sends signal to reciever directly to TV base so they can go live with it and LiveU goes on mobile cards for internet conenction, UTP etc It's nice equipment thx
What are the LiveU Models in field and studio?
digitalalps wrote:What are the LiveU Models in field and studio?
I think lu500
Joined: 4/4/2016(UTC) Posts: 235  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
That is cool about the Behringer as I thought those lower cost boards only had 2 tracks to the PC or Mac. They could mix 16 to 2 but not 16 to 16 on the computer.
That is great news for me. I am interested to see how you handle it on the vMix side, meaning do you bring it in 2 mixed tracks or as individual tracks into vMix.
Thanks.
Rich Shumaker
RichShumaker wrote:That is cool about the Behringer as I thought those lower cost boards only had 2 tracks to the PC or Mac. They could mix 16 to 2 but not 16 to 16 on the computer.
I am still looking into this mixing console and it looks to be only 2 tracks to the PC. Could you verify if you are getting 2 tracks or 16 tracks to the PC. Thanks. Rich Shumaker
XENYX UFX1204 Premium 12-Input 4-Bus Mixer with 16x4 USB/FireWire Interface, 16-Track USB Recorder, XENYX Mic Preamps & Compressors, British EQs and Multi-FX Processor
i use this device and i have avery chanel as input in vmix
Systems
