Important Temporary Patch !!
Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
HOLA MARTIN MERRY CHRISTMAS AND NEW YEAR 2011 to all. Martin could make a temporary patch before the end of the V 9 vMix 2011. to fix the following: 1 - paused and Mov files do not work LOOP or the option OVERLAY 2 - + clean alpha channel. 3 - When you change camera that does not remove the audio (i = audio) because camera changes and you lose the option is null and changes from green to gray automatically .- Activities for many years to record one and all we have material effects in MOV and prefabricated alpha channel. We appreciate your attention that facilitates a temporary patch to continue sponsoring so vMix 2010 this season. apologizes for any inconvenience my translations ++++++++++++++++++++++++++++++++++++================================== HOLA MARTIN FELIZ NAVIDAD Y AÑO NUEVO 2011 , para todos .
Martin podrias hacer un parche temporal antes de que finalices el V 9 VMIX 2011 . que arregle lo siguiente : 1- Archivos Mov pausados y no funcionan los LOOP ni en la opcion OVERLAY 2- canal Alfa mas + limpio . 3- Cuando cambio camara que NO se quite el audio (i=audio) porque en los cambios de camara se pierde la opcion y queda nulo y pasa de verde a gris automaticamente .-
Actividades de fin de año muchas videofilmaciones y todo el material de efectos lo tenemos en formato MOV y canal alfa prefabricados . agradeceria tu atencion que nos facilitares un parche Temporal , para seguir asi patrocinando VMIX 2010 en esta temporada . disculpa por las molestias de mis traducciones
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4740 time(s) in 1626 post(s)
v9 Will be released soon. In the mean time, option 3 is already available under settings untick "Automatically Mix Audio" under the Audio tab.
Thanks Continue waiting then V9 vMix 2011. solving work. thoroughly rectify point # 3. change in the camera is lost or disconnected me. HAPPY NEW YEAR 2011 the great family Vmix 2011
