pm
#1 Posted : Friday, February 3, 2017 3:57:22 PM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Hi
I try to set the audio volume thru API.
If I set a value of 50, then the slider moves to 50%. The XML status reports a value of 6.25
If I set a value of 75, then the slider moves to 75%. The XML status reports a value of 31.6
My final goal is to have a script which reads out current volume, set volume to 0 and fade in until the saved value is reached. But because there are different scales it's not that easy.
So it seems there is some math in between. How is the scale handled in XML status?
Patrick
#2 Posted : Friday, February 3, 2017 4:48:36 PM(UTC)
not audio expert but googled and already found this
http://www.robotplanet.d...ert.php?db=0&pct=100
#3 Posted : Friday, February 3, 2017 5:29:53 PM(UTC)
I was intrigued by your post so I dropped an eye on it by curiosity.
When I move the audio fader by hand in vMix, first I see that they are logarithmic. Meaning putting the fader half-way doesn't mean reducing the volume by half. If one puts his mouse over the fader, it shows the percentage.
So I put the fader at 50% (which is close to the top) and check with the API. XML value is 49.756 (close to 50%)
Do the same for 25% > XML shows 24.951
Do the same for 0 > XML shows 0
So I think XML is working as one expects. There is no math to do...
Guillaume
#4 Posted : Friday, February 3, 2017 5:45:01 PM(UTC)
@DWAM
is as you describe when using the slider but not when you use the percentage values in a shortcut , then you get what PM wrote
pm
#5 Posted : Friday, February 3, 2017 5:45:07 PM(UTC)
pm
Guillaume, thanks for verifying.
That's right. If you move the fader by hand to 50% (accoring mouse over information), the XML value ist approx. 50.
But if you set the volume with SetVolume and value 50, the slider moves to the middle of the fader. Same for value 25, the slider moves to 1/4 of fader position.
Patrick
xaver
#6 Posted : Thursday, August 17, 2017 8:34:14 AM(UTC)
xaver
Patrick
Hi Patrick
did you found the solution?
same problem here
IF setvolume to 70
XLM says 24.01
pm
#7 Posted : Friday, August 18, 2017 4:56:03 PM(UTC)
pm
No, never found a solution for that. Couldn't finish my audio fadein script because of this behaviour.
pm
#8 Posted : Tuesday, September 26, 2017 4:44:38 AM(UTC)
pm
Sorry, have to bump my post.
My audio fade script is still in an unfinished state, because XML value, mouse over info and SetVolume function behaviour don't match.
Is there a chance to get this solved?
Patrick
#9 Posted : Tuesday, September 26, 2017 4:53:57 AM(UTC)
Was thanked: 4742 time(s) in 1628 post(s)
The Volume level in vMix is linked to amplitude and scales with the following formula:
Volume = 0 to 100 (used for UI volume bars)
Amplitude = 0 to 1 (used for API Meter and Volume values)
Decibels = 0 dB to -infinity
Volume = (Amplitude ^ 0.25) * 100
Amplitude = (Volume / 100) ^ 4
Example
VolumeBar = 50
Amplitude = 0.0625
MeterF = 0.0625
VolumeXML = 6.25
I will leave converting amplitude to decibels as an exercise to the reader.
P.S meter values in XML are in Amplitude 0-1, while volume values in XML are in Amplitude 0-100
thanks 4 users thanked admin for this useful post.
DWAM on 9/26/2017(UTC), doggy on 9/26/2017(UTC), pm on 9/26/2017(UTC), stigaard on 9/26/2017(UTC)
stigaard
#10 Posted : Wednesday, April 15, 2020 9:50:04 PM(UTC)
stigaard
Denmark
Perhaps this can be used to calculate dB... http://msp.ucsd.edu/tech....08/book-html/node6.html
