Thremir
#1 Posted : Wednesday, February 1, 2017 6:27:56 AM(UTC)
Thremir
We are working on some cross-platform graphics in HTML (mostly for CasparCG) but these could easily be ported to vMix if we had the possibility to send console commands to the Web Browser.
Cheers,
Håvard
#2 Posted : Wednesday, February 1, 2017 6:52:39 AM(UTC)
Hi Håvard
check http://www.vmix.com/help...utFunctionReference.html
vMix API has commands for internal WebBrowser
Browser
>BrowserBack
>BrowserForward
>BrowserKeyboardDisabled
>BrowserKeyboardEnabled
>BrowserMouseDisabled
>BrowserMouseEnabled
>BrowserNavigate
>BrowserReload
Hope this helps
Guillaume
Thremir
#3 Posted : Wednesday, February 1, 2017 3:28:23 PM(UTC)
Thremir
Thanks for the tip, but that isn't what I was thinking of.
If you press F12 or right click on a website in your browser and press "inspect", you can access the web console. From here you can trigger Javascript to change text or start animations.
