2 Pages<12
kane
#21 Posted : Wednesday, February 1, 2017 1:23:52 PM(UTC)
kane
DWAM wrote:
AFAIK, NDI is not adaptive bitrate. What happens when the bandwidth lowers ?
Guillaume
It will drop (hold previous) frames if the network cannot deliver in time.
Kane Peterson
NewTek
thanks 1 user thanked kane for this useful post.
DWAM on 2/1/2017(UTC)
mjgraves
#22 Posted : Wednesday, February 1, 2017 4:33:27 PM(UTC)
mjgraves
I tried the Newtek NDI Cam app on my Pixel last week. It worked pretty well.
I was just in my home office, within 5m of a Ubiquiti AC Pro WiFi AP. I forced the Pixel to the 5 GHz band to avoid channel congestion issues.
The Pixel did get pretty warm after just 10 minutes. I wonder about battery life.
PFBM
#23 Posted : Friday, February 10, 2017 12:25:06 PM(UTC)
PFBM
Hi Kane !!
please change SD resolution to 640 X 360 to be full 16:9 scale :)
https://pacoup.com/2011/...of-true-169-resolutions/
Cheers,
PFBM
JW
#24 Posted : Sunday, July 16, 2017 9:17:06 AM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
vMix didn't see my Smartphone, after turning off Windows Firewall it worked.
boris9831
#25 Posted : Wednesday, July 19, 2017 4:50:17 PM(UTC)
boris9831
I used this a couple of times for audience fills at conferences - does fairly well. Just make sure you WiFi unit is strong enough to pick up where you are. Got shots I never would have any other way - turned my Android phone into another camera for $20.
Followyourblissmedia
#26 Posted : Tuesday, August 29, 2017 1:08:47 PM(UTC)
@DWAM is there a way to send rtsp or rtmp from Wowza Gocoder straight to vMix locally without touching the wowza servers? Or does it have to hit the server before vmix will recognize it?
#27 Posted : Friday, January 11, 2019 5:23:19 AM(UTC)
GoCoder is an app which works exclusively with Wowza (it used to be open years ago but they restricted it)
However there are several apps for Android and iOS that use several streaming protocols (rtmp, rtsp, webrtc, etc...) and can send a feed directly to vMix.
I have already listed some of them (the ones I know and use) in other threads in this forum. You will find them with the search option.
Guillaume
slb5146
#28 Posted : Thursday, February 14, 2019 8:49:00 AM(UTC)
slb5146
I have two Android Pixel 2's with Newtek NDI app on both. Either one by their self will show up in vMix. When I try to add either one as the second Pixel 2 it will not show up in vMix. I need to record using two Pixel 2's for an event. Any help appreciated.
Steve Brown
mjgraves
#29 Posted : Friday, February 15, 2019 5:19:36 AM(UTC)
mjgraves
Steve Brown
What resolution? What are the specifics of your Wi-Fi?
I wonder if two full NDI stream over WiFi isn't been a little optimistic?
slb5146
#30 Posted : Friday, February 15, 2019 10:13:24 AM(UTC)
slb5146
I have used these Pixel 2's before on a different Gigabit router into the same PC. The PC is hard wired to an AT&T Uverse 5268AC router. I would love to know the resolution and bit rate but I find no options to set either in the Newtek NDI App. The Pixels and connected to the 5 GHz WiFi.
2 Pages<12
