2 Pages12>
STADIORADIO
#1 Posted : Tuesday, January 31, 2017 5:39:53 AM(UTC)
STADIORADIO
Goodmorning everyone. I write for a problem I can not solve. A kind of graphic error. As you can see from the attached image, I often find in the previews of "input", cut part of the graphic. This happens when I open previews, and I'm going to close some applications, like the machine, the computer, he could not handle graphically Vmix.
Yet I can do streaming hd, making replay, and use three cameras. The problem seems to increase when I add a lot of input, for example 20-30. I hope I was clear and that someone can help me.
THANK YOU
My PC has these characteristics
BX80662I76700K Box Processor Intel Core I7-6700K - I7-6700k cpu @ 4.00ghz
Asus Z170-A Intel Motherboard, DDR4 1151
Asus GeForce GTX 950 STRIX graphics card, 2GB GDDR5, DC2OC
Kingston HyperX Fury 16GB Memory Kit, 2x8 GB, 2133 MHz, DDR4, ECC CL14 DIMM
Samsung 850 EVO SSD 250GB, 2.5 "SATA III 6 Gbit / s, 256-bit AES
STADIORADIO attached the following image(s):
#2 Posted : Tuesday, January 31, 2017 7:23:39 AM(UTC)
Can you confirm the latest vMix is installed?
This bug was fixed a few versions back.
STADIORADIO
#3 Posted : Tuesday, January 31, 2017 8:32:00 AM(UTC)
STADIORADIO
I had the problem with 59, Saturday after I had the problem I upgraded to 61 this morning at 63.
A real test as I will do next Saturday. Do you know if there is still the problem.
Thanks Martin
STADIORADIO
#4 Posted : Tuesday, January 31, 2017 4:35:07 PM(UTC)
STADIORADIO
I managed to do a test today, with the latest version. The problem there is still
#5 Posted : Tuesday, January 31, 2017 5:27:13 PM(UTC)
@ STADIORADIO
Are there specific procedures or actions required to 'duplicate' or 'create' this behavior?
I suspect it is GPU and/or CPU related as I have experienced similar "remnant" or "stuck" portions of other windows in the past when I have had a lot of windows open and multiple processes going on while using vMix and alternating and switching between windows.
STADIORADIO
#6 Posted : Wednesday, February 1, 2017 8:41:35 AM(UTC)
STADIORADIO
Yesterday I did a test with the latest version. I was about thirty input. Some "wide / open" other "reduced." The error occurs when I go to reduce / close the on-screen input. I was not doing anything special, no streams, no rec, nothing
#7 Posted : Wednesday, February 1, 2017 9:16:27 AM(UTC)
@ STADIORADIO
A nuisance for sure, what happens if you 're-size' or minimize and restore the main vMix Ui?
STADIORADIO
#8 Posted : Wednesday, February 1, 2017 9:28:42 AM(UTC)
STADIORADIO
what you mean by "main vMix Ui"
#9 Posted : Wednesday, February 1, 2017 9:34:07 AM(UTC)
@ STADIORADIO
vMix main window
UI = User Interface
STADIORADIO
#10 Posted : Wednesday, February 1, 2017 9:43:47 AM(UTC)
STADIORADIO
Ice forgives Ignorance.
I check :-)
STADIORADIO
#11 Posted : Wednesday, February 1, 2017 2:00:54 PM(UTC)
STADIORADIO
if I do I minimize and then restore, the screen is displayed correctly
STADIORADIO
#12 Posted : Wednesday, February 1, 2017 2:07:12 PM(UTC)
STADIORADIO
Please watch the video
STADIORADIO
#13 Posted : Friday, February 3, 2017 3:37:05 AM(UTC)
STADIORADIO
Martin Good morning, good morning IceStream.
Have you seen my video? Think is a prolbema of my PC?
Thank you
#14 Posted : Friday, February 3, 2017 5:00:51 AM(UTC)
Can you check if onboard graphics is enabled in the bios and if so disable it?
I have only seen this screen corruption happen on older systems where both graphics were enabled at the same time.
It also seems isolated to Windows 7.
STADIORADIO
#15 Posted : Friday, February 3, 2017 5:50:16 AM(UTC)
STADIORADIO
#16 Posted : Friday, February 3, 2017 11:04:31 AM(UTC)
@ STADIORADIO
I tend to believe that it is graphics card related.
Is Martin correct in assessing that you are running Windows 7?
#17 Posted : Friday, February 3, 2017 11:07:10 AM(UTC)
The screen cap shows it is windows 7 Greg
#18 Posted : Friday, February 3, 2017 11:38:12 AM(UTC)
@ DWAM
I've learned in life that it is never safe to "assume"...
I am not familiar with Windows 8 and it's themes or how similar they may be to Windows 7, never-the-less, we digress, I'm just seeking confirmation that will validate Martin's assertion that it is an issue isolated to Windows 7.
#19 Posted : Friday, February 3, 2017 11:45:53 AM(UTC)
Not assuming, it's written
#20 Posted : Friday, February 3, 2017 12:07:14 PM(UTC)
@ DWAM
Not to digress further, but perhaps I have missed something...
I don't see it "written" anywhere on the attached images that it is Windows 7.
Where should I be looking?
2 Pages12>
