Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
You need to make png files with those bullets (fouls0.png - empty, fouls1.png with one bullet, fouls2.png etc...)
Then there is a setimage function, make shortcuts to switch from 0 to 5.
Hi! the easiest way is to use characters like ■ or █ for exemple. So you can have a simple text field with as many colored symbols as you need If you want real images, check this topic where we've been talking about doing dynamic xaml files http://forums.vmix.com/d....aspx?g=posts&t=8784Have fun! Guillaume
create xaml title with the 5 seperate boxes linked to a variable to allow you to change the color ( any color you want)
r@wisla wrote:You need to make png files with those bullets (fouls0.png - empty, fouls1.png with one bullet, fouls2.png etc...)
Then there is a setimage function, make shortcuts to switch from 0 to 5. By the way that image capture is taken from youtube stream from Poland today :-) and stream was done by vMix
no messing around with images here you go ,just right click for title editor and choose color File Attachment(s):  colorblock.xaml (3kb) downloaded 111 time(s).You cannot view/download attachments. Try to login or register.
second variation where you can WRITE the color as text hence usable with set text in shortcuts File Attachment(s):  colorblock2.xaml (3kb) downloaded 142 time(s).You cannot view/download attachments. Try to login or register.
 2 users thanked doggy for this useful post.
doggy wrote:no messing around with images
Thanks, this is just enough. Great!
doggy wrote:second variation where you can WRITE the color as text hence usable with set text in shortcuts
And this is even better !!
-TA_ wrote:r@wisla wrote:You need to make png files with those bullets (fouls0.png - empty, fouls1.png with one bullet, fouls2.png etc...)
Then there is a setimage function, make shortcuts to switch from 0 to 5. By the way that image capture is taken from youtube stream from Poland today :-) and stream was done by vMix Not by me ;-) But this is my stream done with vMix, with the same effect -TA_ wrote:doggy wrote:second variation where you can WRITE the color as text hence usable with set text in shortcuts
And this is even better !! Only if your bullet is one color txt, not gradient etc (see my euroleague stream)
r@wisla wrote:-TA_ wrote:r@wisla wrote:You need to make png files with those bullets (fouls0.png - empty, fouls1.png with one bullet, fouls2.png etc...)
Then there is a setimage function, make shortcuts to switch from 0 to 5. By the way that image capture is taken from youtube stream from Poland today :-) and stream was done by vMix Not by me ;-) But this is my stream done with vMix, with the same effect It was http://lajfytv.pl/ and 4 nations Futsal tournament in Tuchy -TA_ wrote:doggy wrote:second variation where you can WRITE the color as text hence usable with set text in shortcuts
And this is even better !! Only if your bullet is one color txt, not gradient etc (see my euroleague stream) Yep but one color is fine atleast now
one can always put an OpacityMask on the blocks to give it some dimensional effects in your design among other design features ;-) doggy attached the following image(s):  Screenshot (50).png (114kb) downloaded 99 time(s).You cannot view/download attachments. Try to login or register.
a nice example posted by JAIRODJ (link) showed an example of using just one color change to adjust a title background with several layered effects/opacitymasks (apparently download link does not work anymore) doggy attached the following image(s):  Screenshot (51).png (29kb) downloaded 57 time(s).You cannot view/download attachments. Try to login or register.
Originally Posted by: doggy  second variation where you can WRITE the color as text hence usable with set text in shortcuts
It's great. How to make this kind of title? Is it possible with GT Title Designer?
