NordicSound
#1 Posted : Thursday, January 10, 2013 7:49:53 PM(UTC)
NordicSound
Hello again everybody,
While testing recording I have found a problem, I have 2 sources, 2 movies clips, one with anamorphic 720x304 resolution and the other with widescreen 720x400 resolution. When recording avi to disk I have selected to record to PAL DV with 320x240 resolution. When i'm opening the recorded avi file, it has 720x576 resolution. I have checked Recording Setup window. AVI tab contents: Size - 320x240, System - PAL 50i or 25p, Codec - DV Video Encoder, File Format - AVI. Then, i have checked Settings window, Display tab it says Output Size is 320x240 too but the final video recording has a 720x576 resolution. I have tried also recording only the anamorphic video with original size of 720x304 but still do the same, it doesn't record at 320x240.
Would you like to help me?
Thanks in advance.
#2 Posted : Thursday, January 10, 2013 8:46:40 PM(UTC)
The DV Encoder has a fixed resolution, so regardless of what is selected as the resolution it will be resized to 720x576 (PAL) or 720x480 (NTSC).
This is a restriction of the DV format itself, so if you want to record to another resolution you will need to use another codec such as the DeckLink MJPEG option (if available)
