Eliot Hochberg
#1 Posted : Thursday, January 26, 2017 4:33:51 PM(UTC)
Eliot Hochberg
Hello!
I'm building a 6 or 7 camera HDMI setup, and have a few possible paths. Looking for any gotchas that I can avoid. All start with the Emerald reference system.
Option 1:
two Magewell quad HDMI cards instead of one
Total cost: around $2700, not including cables
Option 2:
one Magewell quad HDMI, one Magewell dual HDMI
Total cost: around $2400, not including cables
Option 3:
One Magewell quad HDMI, two Blackmagic Intensity HDMI capture
Total cost: around $2200, not including cables
Here's the thing, though: I have one run that's over 30 ft. So I'm concerned about signal loss. And this system will also be used once a year for a show that has two cameras at 100ft from the system. I read that there are optical HDMI cables that can do 300 ft, but I'm not sure about it. However, the next option seems like it might work:
Option 4:
One Blackmagic Decklink Quad 2 PCIe 4 Lane - each connector can be either input OR output, meaning up to 8 inputs; 6 HDMI to 3G-SDI converters
The question: does the last one sound like it will work? If it does, it gives a lot of flexibility, and up to 8 inputs for $300 less. And, if I upgrade cameras, the system would still be viable.
Thoughts?
#2 Posted : Thursday, January 26, 2017 5:26:00 PM(UTC)
@ Eliot Hochberg
Personally, I would opt for the "professional" SDI option. Even though I have a slight bias against the BMD products because of their 'finickiness', the Decklink Quad2 is still the most affordable per Input/Output option out there that definitely gives you more potential in the long run.
Eliot Hochberg on 1/26/2017(UTC)
SHMD
#3 Posted : Thursday, January 26, 2017 7:26:58 PM(UTC)
SHMD
Canada
Was thanked: 52 time(s) in 31 post(s)
@ Eliot Hochberg
I am almost done a build that was going to be based on the Emerald specs.- but after some research I went with the Ruby specs with a i5 processor as the gaming 5 motherboard is a little more flexable in features for the same price when I was shopping for parts. Also will be easy to just add an i7 down the road to upgrade.
Just a heads up that the Gigabyte Z170MX-Gaming 3 and Gaming 5 share lanes withe PCI-e and M.2, so in both cases each motherboard will only give you one x4 PCI-e after you install a GPU card in the x16 slot.
The specs also say if you place a card in the x8 PCI-e slot it makes the x16 slot a 8 also... Not sure how that will work as vmix recomends the
Gigabyte Z170MX-Gaming 5 with the BMD Quad 2 which is a x8 card. I am new to PC builds, but I would figure you want the GPU running at full x16?
-sheldon
thanks 1 user thanked SHMD for this useful post.
Eliot Hochberg
#4 Posted : Thursday, January 26, 2017 8:18:51 PM(UTC)
Eliot Hochberg
If it's close to the same price, more throughput would seem to be the way to go. I'll look into this.
SHMD
#5 Posted : Thursday, January 26, 2017 8:46:04 PM(UTC)
SHMD
Canada
I just posted the question about x8 card support also... as I am not sure if it works or not.
-sheldon
SHMD
#6 Posted : Friday, January 27, 2017 8:21:13 AM(UTC)
SHMD
Canada
You will be fine with the Gaming 5 board listed in the Ruby specs. Read vmix (Martin's) response in my question I posted about pci lanes...
http://forums.vmix.com/d...p;m=33682&#post33682
-sheldon
Eliot Hochberg on 1/27/2017(UTC)
Eliot Hochberg
#7 Posted : Friday, January 27, 2017 2:55:34 PM(UTC)
Eliot Hochberg
That was a technical reply they gave!
So as I understand it, you can have x16 in PCIe 2.0, and in that event, there would be bandwidth issues. But because that board does PCIe 3.0, the two cards have to share their connections, but despite having half the data lanes due to the throttle down of the x16 port, since it's twice as fast, there is no issue?
And a little research shows that it's hard to find a faster combination, one assumes for cost reasons.
Does that sound right?
Eliot Hochberg
#8 Posted : Thursday, February 2, 2017 1:18:07 AM(UTC)
Eliot Hochberg
Ok, here's what I ended up ordering:
GIGABYTE Aorus GA-Z270X-Gaming 7
Intel Core i5 6500 32GHz Processor Silver
Gigabyte GeForce GTX 1060 Mini ITX OC 3G Graphics Card
Patriot 16GB Viper 4 DDR4 3200 MHz
Corsair Carbide Series Quiet 400Q Mid-Tower Case
Samsung 850 EVO 500GB Internal SATA Solid State
WD Mainstream 3TB Internal Serial ATA Hard Drive
Thermaltake Smart DPS G 700W 80 Plus Bronze Semi-Modular Power Supply
Wish me luck!
#9 Posted : Thursday, February 2, 2017 9:49:55 AM(UTC)
@ Eliot Hochberg
Looks like an awesome vMix system for what you have in mind.
Eliot Hochberg on 2/2/2017(UTC)
SHMD
#10 Posted : Thursday, February 2, 2017 2:37:49 PM(UTC)
SHMD
Canada
Looks like a great build...
Simular to the build I just finished doing...
-sheldon
