I have an Arturia Beatstep Pro midi controler. It's nice because I have 8 butons for output and 8 buttons for preview. But I need help for use activators on this controller. I'll turn on button when the input are online.
Thank you for your help ! Emile
Salut Emile here's a tutorial video for activators. Bien à toi Guillaume
Salut,
Merci pour ta réponse, mais cela ne fonctionne pas avec mon panel midi. J'avais déjà suivi ce tuto. Je me demande s'il y a quelques choses à configurer pour ce panel, ou s'il faut que ce dernier soit supporter par vMix ?
Bien à toi, Emile
@ emylio
It could be that that particular device is not directly supported when it comes to activating the LED's of the device (as I assume you've tried all the options in the "Type" dropdown menu, but certainly worth a try if you haven't). As near as I can figure, there is only one light (white) for each of the main buttons you reference, so one wouldn't think it would be too complex to implement for the team at vMix and thus worth a feature request if none of the other options work, but keep in mind that there are probably thousands of MIDI devices out there and it might not be possible for vMix to take advantage of the features of each one. Other than not lighting up, though, I trust the buttons (and device in general) works fine as a control surface with the "Shortcuts" feature?
