Hardware Compatibility
Tally lights problem with Arduino Mega (SOLVED).
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
I found a big problem about tally lights connected to Arduino Mega. In Arduino Uno everything works perfect but in Arduino Mega doesn't. You can see evrything in this video: Any advice?
Thank you for your answer, I made averything you wrote but still "connect error".
Normally with Arduinos we need to define 2 things: - the board model - the COM port
Try this: - close vMix - run Arduino IDE - set it correctly for your MEGA board and COM port - make sure it works then: - close the IDE - re-open vMix - give it a try
This could make the registry "remember" correctly the last config (with MEGA) instead of the previous one (with UNO)
DWAM wrote:Normally with Arduinos we need to define 2 things: - the board model - the COM port
This is exactly what I did.
I have the same problem. Arduino Uno Works, Arduino Mega doesn't work. I made all things suggested by the guide in knowledge base but it doesn't work.
Joined: 3/2/2017(UTC) Views messages in topic : 1 Location: US
spino wrote:I found a big problem about tally lights connected to Arduino Mega. In Arduino Uno everything works perfect but in Arduino Mega doesn't. You can see evrything in this video: Any advice? Arduino mega is better than arduino uno. Tally lights works perfect in uno. The Arduino Mega has 54 pins and uno has less pins. For more details, you can visit my post Arduino Mega Vs Arduino UNO.
Problem solved in Vmix 19.
Joined: 3/2/2017(UTC) Posts: 1 Location: Virginia, USA
Hi....i am new user here. I have the anode on row 13, and the cathode on row 14. I believe that's how the book has it.What happens if I use the wrong size resistor? It just won't work? I think I have the 220-ohm, but I can't tell for sure. I have a 5 band, because I don't see and 220-ohm 4 band resisters in my kit.
PeterJohn wrote:Hi....i am new user here. I have the anode on row 13, and the cathode on row 14. I believe that's how the book has it.What happens if I use the wrong size resistor? It just won't work? I think I have the 220-ohm, but I can't tell for sure. I have a 5 band, because I don't see and 220-ohm 4 band resisters in my kit. Take a look here: I also suggest to take a look to the tutorials about Arduino in Youtube: just the first lessons.
